I have created an XLS form and trying to import it into ODK Central.
I want a front page of the form with some branding of project.
I have added a note and image as advised by the online forum.
But if I have this block, the choices of the following blocks do not show.
Please try the attached sample form
If I remove the the note with images it works...
All columns representing user-facing text or media can be multi-lingual:
If you replace label::English (en) on your choices sheet with label, the form will work. (But this will also break any custom required_message::English (en) values (none in the example)
OR, if you change the image column title on the survey sheet to image::English (en), the form will also work, and so will the required_message
Removing the label::English (en) in the choices sheet to `label' worked.
But
Changing the image column title on the survey sheet to image::English (en) did not work. It through a validation error.
Error: ODK Validate Errors:
>> XForm is invalid. See above for the errors.
: Question <label> '${buzaaya_1}:label': text is not localizable for default locale [English (en)]!
The following files failed validation:
${CopyofBuzaaya-Union-Farmer-Registraion}.xml
Result: Invalid
Removing the language in label is non-intuitive. Thanks for your help.
