I am facing a deadline to complete a questionnaire in ODK But I have two
problems that needs to be solved before tomorrow.
Qa: Did you or anyone else in your household receive cloths? ( select all
that apply)
1=Yes myself
2=Yes someone else in the household
3=no
4=not applicable
8=dont know
Only 1 and 2 can be selected as a combination. below is the question
Qb: I have constructed a roster and attached is the file.
I want to have a line_ID generated before one enters the first hh member
name.... and then line ID geneted again once one enters the second hh
member name.
Please note that this is a mailing list of volunteers. There are no
guarantees of responses (timely or otherwise). This is especially true on
weekends.
Qa. It sounds like you'd like it so if someone selects 1 or 2 they can't
also select 3 or 4 or 8. The way to do that is with a constraint.
not((selected(., '1') or selected(., '2')) and (selected(., '3') or
selected(., '4') or selected(., '8')))
Qb. I have no idea what you are asking. There is no such thing as a line ID.
On Sun, Oct 30, 2016 at 3:20 PM, Rod wrote:
Dear all,
that apply)
1=Yes myself
3=no
4=not applicable
8=dont know
member name.
The second part of your question sounds like you want to create a
calculation at the start of your roster with:
position(..)
That will record the line number of that record within the roster.
Jason
On Monday, October 31, 2016 at 7:36:58 AM UTC-4, Yaw Anokwa wrote:
> Hi Rod,
> weekends.
> ID.
> Yaw
> On Sun, Oct 30, 2016 at 3:20 PM, Rod <sydney...@gmail.com > wrote:
>> Dear all,
>> that apply)
>> 1=Yes myself
>> 3=no
>> 4=not applicable
>> 8=dont know
>> member name.
>> Please help help
>> "ODK Community" group.
weekends.
ID.
that apply)
1=Yes myself
3=no
4=not applicable
8=dont know
member name.
position(..)
Jason
Hi Rod,
weekends.
ID.
two problems that needs to be solved before tomorrow.
all that apply)
1=Yes myself
3=no
4=not applicable
8=dont know
member name.... and then line ID geneted again once one enters the second
hh member name.
Groups "ODK Community" group.
