In the ODK Collect app installed on my phone, I can see the form on this
server. But I am not able to download it. I get the following error:
"Mobile Communities (ID: mob_comm) - Error: Not Found (404) at http://muc.iiitd.edu.in/formXml?formId=mob_comm"
As you can see the port no. has been removed from the download link.
This supports the above claim that the port no. has been removed from the
download link by the ODK Aggregate.
The solution that the help provided was to install the ODK Aggregate VM. I
have done that umpteen no. of times but to no avail. I have got this same
error every single time.
I am still using default logins. So you all can see the issues for yourself.
It would be great if you guys could please look into the issue. Any kind of
help or suggestion is appreciated.
Can you verify that you can access the server from an outside computer
as some universities run firewalls?
One thought is in Collect is to try to use the Other option in in
Server Platform in the "General Settings" because other was added to
give people more ability to control their URLs when creating an
aggregate alternative. It might fix the problem.
Waylon
On Wed, Feb 20, 2013 at 10:31 AM, wrote:
> Hi,
> I am Karan Kalra, a 3rd year undergraduate student studying B.Tech (CSE) at
> IIIT - Delhi. I am working on ODK as a part of my B.Tech Project.
> I had used the ODK-Aggregate-VM-1.3.0.0
> (https://gumroad.com/l/odk-aggregate-vm) and set it up using NAT and port
> forwarding at http://muc.iiitd.edu.in:9250/openid_login.html. I am able to
> login into the ODK Aggregate at have uploaded a form.
> I google up the issue. There was help available on this link.
> http://code.google.com/p/opendatakit/wiki/AggregateTroubleshooting#Form_List_shows_but_Downloads_Fail
> As the help says, I checked out this link.
> http://muc.iiitd.edu.in:9250/xformsList
> The DownloadUrl says this:
> Also, there probably is an issue with the url redirects too. Try pasting
> this in your browser. http://muc.iiitd.edu.in:9250/
> When the ODK Aggregate has set up its own server, this should work. But the
> redirect goes haywire here and I am directed to this link.
> http://muc.iiitd.edu.in/openid_login.html?redirect=http%3A%2F%2Fmuc.iiitd.edu.in%3A9250%2FAggregate.html
> Clearly again, the port no. has been omitted from the redirect as the
> correct redirect should have been at
> Thanks.
> Karan
> "ODK Developers" group.
> email to opendatakit-developers+unsubscribe@googlegroups.com.
> For more options, visit https://groups.google.com/groups/opt_out.
I think your Aggregate install is picking up the IP and port of the VM
and using that as the base URL. There's no easy way around this in the
VM.
Instead what i'd recommend is to install Tomcat/MySQL on your machine,
and use the Aggregate installer to generate a new WAR. When you do the
install, use http://muc.iiitd.edu.in:9250 as the fully-qualified
domain.
Need ODK help? Go to http://nafundi.com for custom development,
professional support, form design, implementation advice, and user
training for ODK.
I have ODK Collect 1.2.2 (1023) installed on my Android 4.0 phone. When I
change the 'Server Platform' in 'General Settings' from 'ODK Aggregate' to
'Other', I get no change in the options. I probably have tried everything
from ODK Collect to solve this problem. The problem most probably lies in
On Thursday, February 21, 2013 5:03:58 AM UTC+5:30, Waylon wrote:
> I have tried to navigate to http://muc.iiitd.edu.in:9250/ from the USA
> but I keep getting "The server at muc.iiitd.edu.in is taking too long
> to respond." I also tried http://muc.iiitd.edu.in:9250/Aggregate.html
> with no luck so it's hard to reproduce.
> Waylon
> On Wed, Feb 20, 2013 at 10:31 AM, <karan...@iiitd.ac.in > wrote:
> > Hi,
> at
> port
> to
> the
> I
> same
> the
> yourself.
> of
> > Thanks.
> > Karan
> Groups
> an
I had already thought of that option. It is possibly the last resort.
I had a few doubts. Do I let the HTTP/1.1. Connector Port remain as
default, i.e. 8080? Also, do I enter the Internet-visible IP address or DNS
name as muc.iiitd.edu.in:9000?
If I do both these things, I am told that I can access the link
http://muc.iiitd.edu.in:9000:8080/ODKAggregate. Now this doesn't seem a
good idea to me.
On Thursday, February 21, 2013 6:03:08 AM UTC+5:30, Yaw Anokwa wrote:
> Hi Karan,
> VM.
> domain.
> Yaw
> training for ODK.
> > Waylon
> >> Hi,
> (CSE) at
> port
> able to
> this
> the
> VM. I
> same
> pasting
> the
> yourself.
> kind of
> >> Thanks.
> >> Karan
> Groups
> an
> Groups "ODK Developers" group.
> an email to opendatakit-developers+unsubscribe@googlegroups.com.
good idea to me.
Hi Karan,
VM.
domain.
training for ODK.
VM. I
same
yourself.
kind of
Thanks.
Karan
Groups
an
email to opendatakit-developers+**unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out.
an email to opendatakit-developers+**unsubscribe@googlegroups.com.
I too wasn't really sure if that would work. But then if you use
muc.iiitd.edu.in:9000 as the DNS name, the ODK Aggregate installer appends
the port HTTP port to the url by itself. One way I thought of working
around that was changing the Tomcat Apache server's port from 8080 to 80.
That ways probably 80 won't be appended in the url. Do you think this would
work?
On Friday, February 22, 2013 11:51:08 PM UTC+5:30, Yaw Anokwa wrote:
> Karan,
> I don't think double ports (9000:8080) are valid as URLs. And if I had to
> guess, I'd use muc.iiitd.edu.in:9000 as the DNS name.
> Yaw
> Need ODK help? Go to http://nafundi.com for custom development, form
> design, implementation support, and user training for ODK.
> On Fri, Feb 22, 2013 at 10:18 AM, <karan...@iiitd.ac.in >wrote:
>> Hi Yaw,
>> good idea to me.
>>> Hi Karan,
>>> VM.
>>> domain.
>>> Yaw
>>> training for ODK.
>>> USA
>>> > to respond." I also tried http://muc.iiitd.edu.in:9250/**
>>> Aggregate.html
>>> > Waylon
>>> >> Hi,
>>> (CSE) at
>>> >> (https://gumroad.com/l/odk-**aggregate-vm)
>>> >> forwarding at http://muc.iiitd.edu.in:9250/**openid_login.html.
>>> I am able to
>>> this
>>> >> http://muc.iiitd.edu.in/**formXml?formId=mob_comm"
>>> >> http://code.google.com/p/**opendatakit/wiki/**
>>> AggregateTroubleshooting#Form_**List_shows_but_Downloads_Fail
>>> >> http://muc.iiitd.edu.in:9250/**xformsList
>>> >> http://muc.iiitd.**edu.in/formXml?formId=mob_comm
>>> the
>>> VM. I
>>> same
>>> pasting
>>> But the
>>> >> http://muc.iiitd.edu.in/**openid_login.html?redirect=**
>>> http%3A%2F%2Fmuc.iiitd.edu.in%**3A9250%2FAggregate.html
>>> yourself.
>>> kind of
>>> >> Thanks.
>>> >> Karan
>>> Groups
>>> send an
>>> >> For more options, visit https://groups.google.com/**groups/opt_out.
This is a situation similar to that of another user...
There are two hostname and port combinations to keep separate in your
mind.
(1) the hostname and port to which a browser or ODK Collect device will
connect ( if I'm following the e-mail chain, this is muc.iiitd.edu.in:9000)
(2) the hostname and port on which ODK Aggregate is running (again, if I'm
following the e-mail chain, this is the IP address of the VM and port of
the deployment on that VM (e.g., 8080)),
When you run the ODK Aggregate installer, you must specify the values for
(1); the values for (2) are entirely irrelevant w.r.t. the installer.
So when you run the ODK Aggregate installer to generate the war file that
is deployed on the VM, you should specify:
HTTP/1.1 Connector Port: 9000
Internet-wide IP address or DNS name: muc.iiitd.edu.in
Then deploy that war file onto the VM.
NOTE: I am unfamiliar with the mechanism for configuring the VM. If the ODK
Aggregate installer is not executed, then hopefully these two values are
requested during the VM configuration process.
You would then set up host or port forwarding for muc.iitd.edu.in, port
9000 to send traffic to the IP address of the VM and port on which ODK
Aggregate is deployed on that VM (port 8080).
appends the port HTTP port to the url by itself. One way I thought of
working around that was changing the Tomcat Apache server's port from 8080
to 80. That ways probably 80 won't be appended in the url. Do you think
this would work?
Karan,
to guess, I'd use muc.iiitd.edu.in:9000 as the DNS name.
If I do both these things, I am told that I can access the link http://muc.iiitd.edu.in:9000:**8080/ODKAggregate. Now this doesn't seem
a good idea to me.
Hi Karan,
VM.
domain.
training for ODK.
computer
VM. I
same
yourself.
kind of
The VM's Tomcat install listens on port 80. There is also no
internet-wide IP address configured with that WAR. Aggregate just uses
whatever IP it gets.
Both are config options that enable easier setup for most users, but
I'm guessing that combination is what might be at the root of Karan's
problem.
There are two hostname and port combinations to keep separate in your mind.
following the e-mail chain, this is the IP address of the VM and port of the
So when you run the ODK Aggregate installer to generate the war file that is
You would then set up host or port forwarding for muc.iitd.edu.in, port 9000
to send traffic to the IP address of the VM and port on which ODK Aggregate
the port HTTP port to the url by itself. One way I thought of working around
that was changing the Tomcat Apache server's port from 8080 to 80. That ways
probably 80 won't be appended in the url. Do you think this would work?
Karan,
http://muc.iiitd.edu.in:9000:8080/ODKAggregate. Now this doesn't seem a good
idea to me.
Hi Karan,
VM.
domain.
training for ODK.
computer
this
VM. I
same
pasting
But the
yourself.
kind of
When you have port forwarding across hosts, it is often hard to maintain
the original hostname and port through the request path; in this case, the
original port is getting lost. Also, when executing any of the background
tasks like generating CSV export files or KML files, without the explicit
host and port identified, these background activities won't know what
hostname and port to supply when emitting links that point back to the ODK
Aggregate instance.
If the VM doesn't allow for configuring the host and port values on which
the incoming request arrives, rather than defaulting to the values passed
through on the http request, it is likely to result in quirky behavior.
On Sat, Feb 23, 2013 at 1:57 PM, Yaw Anokwa wrote:
Mitch,
problem.
mind.
I'm
the
that is
ODK
9000
Aggregate
appends
around
ways
Karan,
to
or DNS
seem a good
idea to me.
Hi Karan,
VM
the
VM.
machine,
the
domain.
training for ODK.
computer
to
on
this
error:
link.
from the
Aggregate
VM. I
this
same
pasting
work.
But the
yourself.
Any
kind of
