Marked up images taken in landscape orientation are delivered in a different resolution to portrait, landscape images lose some detail vs portrait.
Portrait: 1600x2134 (~3.4MP) : Maxed out 1600px wide = screen dimension as soft buttons display on short side of screen
Landscape: 1990x1492 (~2.9MP) : Resized from 1600px tall to 1492px tall due to soft buttons taking up 108px on long side of screen
Samsung Galaxy Tab S6 SM-T865 (screen res 2560x1600, camera set to 4:3 aspect)
Collect 2021.3.4
I checked this before I twigged to the reason why, not relevant.
Check device screen resolution isn't lowered - OK, can't change
max-pixels is 2560, and non marked up images are 2560px long, OK
Screen shot on misbehaving tablet was 2560x1600 - OK
Photo taken in camera app was 4128x3096 - OK
Camera settings are OK, 4:3, non HEIF, no option to change resolution
Project settings \ Form Management \ Image Size : Original size from camera - OK
Create a form with an image widget with annotate, annotate a portrait and also a landscape image, ensure max-pixels is >screen resolution, compare delivered image dimensions.
Observe when marking up that app switch/home/back soft buttons sit in different areas for portrait and landscape markup and reduce the 'screenshot' area for a landscape marked up image if the captured image has a squatter aspect than the screen, opposite problem for portrait images and captured image aspect taller than screen resolution.
For my 4:3 camera aspect setting, for a portrait image the soft buttons sit on unused grey area, as the image is squatter than the screen aspect so it's letterboxed.
But for landscape images the 4:3 image is now pillarboxed (grey areas are still along the short edges), so the soft buttons rendered on the long edge don't allow the image to maximise its vertical height.
