If I set the minimum of an integer field to '2' and maximum to '5'
odkBuild generates 'constraint="(. > 2 and . < 5)'
entering a value of 2 in odkCollect results in an invalid response message.
regards
Neil
regards
Neil
Hi Neil:
You are correct; I should probably add a checkbox to specify whether you want inclusive or exclusive ranges. I'll do that soon. Thanks for the feedback!
—Clint Tseng
