On Thu, Feb 19, 2015 at 10:47 AM, Angelo Lazzari wrote:
> Yaw, did you have time to check about the thing i pointed out?
> Thank you very much!
> Angelo
> El Sun Feb 15 2015 at 06:01:10, Angelo Lazzari () escribió:
>> ok, thank you Yaw!
>> Angelo
>> El El Sun, Feb 15, 2015 a las 05:18, Yaw Anokwa
>> escribió:
>>> Hi Angelo,
>>> I'll look into this early next week. Remind me if you don't hear back
>>> by the end of the week.
>>> Yaw
>>> Need ODK services? http://nafundi.com provides form design, server
>>> setup, professional support, and software development for ODK.
>>> On Fri, Feb 13, 2015 at 7:20 AM, Angelo Lazzari wrote:
>>> > Hi, i replicated in a simple form a possibile bug, even is a limit
>>> > situation
>>> > i point it just to know that app behave in a rare way.
>>> > So, i have two simple questions with select externa... where the second
>>> > base
>>> > a choice_filter on the first question.
>>> > In the case the first question has 4 possibile response...and the first
>>> > and
>>> > last response has the SAME LABEL ("RESPONSE 1")
>>> > .... the ODK collect do not recognize correctly which response (NAME)
>>> > has
>>> > been selected...
>>> > actually seems that the ODK collect take in consideration not only the
>>> > NAME
>>> > (that has to be unique) but the label too....
>>> > I attached the simple example of what i had...
>>> > Thank you very much
>>> > Angelo
>>> > You received this message because you are subscribed to the Google
>>> > Groups
>>> > "ODK Developers" group.
>>> > To unsubscribe from this group and stop receiving emails from it, send
>>> > an
>>> > email to opendatakit-developers+unsubscribe@googlegroups.com.
>>> > For more options, visit https://groups.google.com/d/optout.
>>> You received this message because you are subscribed to the Google Groups
>>> To unsubscribe from this group and stop receiving emails from it, send an
On Thu, Feb 19, 2015 at 11:02 AM, Angelo Lazzari wrote:
> ok thanks!
> Angelo
> El Thu Feb 19 2015 at 17:57:44, Yaw Anokwa () escribió:
>> Alas, no. I'll let you know when I do.
>> > Angelo
>> >> ok, thank you Yaw!
>> >> Angelo
>> >> escribió:
>> >>> Hi Angelo,
>> >>> Yaw
>> >>> > situation
>> >>> > second
>> >>> > base
>> >>> > first
>> >>> > and
>> >>> > (NAME)
>> >>> > has
>> >>> > been selected...
>> >>> > the
>> >>> > NAME
>> >>> > Thank you very much
>> >>> > Angelo
>> >>> > Groups
>> >>> > send
>> >>> > an
>> >>> Groups
>> >>> an
>> > Groups
>> > an
