Hi Everyone,
I need to do daily updates on the media file attached to a survey form (it is a csv file containing a list of names and phone numbers that change each day, but the survey form remains the same).
I can upload a form + media file at the same time with the following:
curl --verbose --digest --user UserName:Password
--header "Content-Type: multipart/form-data"
--form "form_def_file=@/Users/FILE_PATH_TO_FORM/Test.xml"
--form mediaFiles=@/Users/FILE_PATH_TO_MEDIA/comm_db.csv
https://XXX.appspot.com/formUpload
But I would like to be able to:
- Post a media file to an existing survey form (that already contains submissions);
- Delete a media file that is attached to an existing survey form, without deleting the form and submissions.
I am using the latest version of ODK Aggregate on Google App Engine.
My operating system is macOS 10.13.4, and I'm using iTerm2 3.1.6
I have tried substituting '--form_id Test' instead of
I have also tried curl DELETE, with various combinations of flags (modeled after what works for Ona.io, below)
I currently use Ona.io, and I am able to accomplish the above tasks with the following:
Post a media file to existing form:
curl -X POST -F 'data_type=media' -F 'data_value=ret_comm_db.csv' -F 'xform=FormID' -F 'data_file=@/Users/FILE_PATH_TO_MEDIA/comm_db.csv' https://api.ona.io/api/v1/metadata.json -u UserName:Password -
Delete media file without deleting form:
curl -X DELETE https://api.ona.io/api/v1/metadata/MediaID -u UserName:Password
Any help would be much appreciated --- thank you!!
Nicholai
