Pre-fill data in survey
Hi there,
I'm using the odk survey to track utilisation of a program where I am collecting information on the repeat programs users. Each time they attend the program they provide their full name.
However there are a fair few typos - english is not the main language of some of the program users - meaning I have to spend a fair bit of time cleaning the data.
Is there anyway I can setup the odk survey to pre-fill once someone filled in the survey once. So when they start to type their name, options appear that they can select.
Many thanks,
Ivan
Hi @Ivan_Pavkovic, it is possible to pre-load the names of the users and use the search appearance to search for any name which in part of the pre-loaded data by starting to type the name you are looking for, it will be sorting the names base on the letters you begin typing with.
fabla2020@gmail.com
Hi Fabla,
Many thanks for getting back to me.
Ivan
Hi @Fabla,
I thought I had found the solution using the directions here - http://xlsform.org/en/#pre-loading-csv-data - where it described how to Pre-Load data.
However it's not working for me.
I've saved a cvs file in my media /odk/forms/formname-media folder on your phone and included _key at the end of the column name where I would like my survey to read/reference the cvs file (in the media folder). However it does not appear with any options.
My understanding is that if I want to pull data (from a defined list of data) I would use the pulldata function. However I want my survey to only provide the option of utilising data from the cvs file in the media folder. I don't want to retain the option for them to just enter the data in by themselves.
Am I on the right track? I feel like the instructions on http://xlsform.org/en/#pre-loading-csv-data are little bit light on...
can you share a sample file and explain how you want it to work
