Hello everybody,
I really appreciate any hints and advice to my issue:
***Background:
I am programming a household survey as a follow-up to a former survey. I want to load previously collected data (in particular: Names of the household members and their occupations) into the new forms and ask follow-up questions about the occupations.
***What have I done so far:
I managed to pre-load the names and occupations (using .csv files and uploading them with the forms to aggegate).
I generated a new "variable" for each loaded name and wrote down the questions for each housheold member line by line.
*** Problem:
This makes the Excel sheet incredibly long (we have up to 15 members per household), it is tedious and error-prone and I wonder whether it is possible to use a repeat group to load each name and occupation one-by-one and then ask the followup questions within the repeat group - so I only have to write them down once.
Please feel free to ask if somethin has not been clear or if you need any more info.
I am looking forward to your support!
Rebecca
Hello Paul,
thank you for your response!
Regarding your first remark: I'm not sure I understand the question correctly. I want to preload data to shorten the interview time.
Regarding your second remark: Can you explain how to do a repeat group with pre-loaded data?
Let me clarify my approach a little further:
For each household, I load the names and occupations of the household members from the previous interviews and then late ODK calculate variables for each name and occupation.
e.g.
name1 = Aaron
occupation1 = Farmer
name2 = Bella
occupation2 = Shop owner
Subsequently, I can reference these in the questions:
"Previously, you said that ${name1} is a ${occupation1}. Is this still correct?"
However, this will get VERY long and complicated as soon as I add more household members and follow-up questions.
Thus, I would like to create a repreat group to load the first name and occupation, ask the follow-up questions and only then load the next one.
I'll include the form and .csv in short version for you to make it clearer.
Rebecca
odk_preload.csv (503 Bytes) odkforum_q.xml (5.6 KB)
I would still appreciate any comments and recommendations!
Rebecca,
In the pre-loaded csv file you could add a count for each household as a column. This would then be pre-loaded and linked to the repeat counter.
Would you be able to share the xml file as an xls file? I could try design something for you.
Asante,
Paul Macharia
Hello Paul,
thanks for the offer. I am looking forward to your suggestion! Find attached the file .xlsx file.
odkforum_q.xlsx (16.3 KB)
