Let’s say I want to preload a text question with a combination of the values from previous questions.
Should I use calculate()
with concat()
? Or is there an easier way?
with concat()
In playing around using text from previous questions, I found that spaces between values won't be respected but if you have a hard-coded character it will allow enforcing a space. So if word_1=alpha, word_2=beta, and word_3=charlie.
lorem ${word_1}. ${word_2}. ${word_3}. ipsum
lorem alpha. beta. charlie. ipsum
lorem ${word_1} ${word_2} ${word_3} ipsum
lorem ${word_1}${word_2}${word_3} ipsum
lorem alphabetacharlie ipsum
calculate
such as concat(${word_1}, " ",${word_2}," ",${word_3})
will allow you to insert the spaces between the valuesSo I think it depends on how you need to combine your values and your hard coded text.
${last_name}, ${first_name}
should be fine without a calculate
and concat()
but if you want ${first_name} ${last_name}
with the space you will need the concat()
@danbjoseph super helpful, thank you!
Just so I'm clear, in the case where I don't need calculate
, would I put the value to be preloaded ($ exprs and all) directly into the instance
or is there some other bind
attribute I should use?
Also if anyone knows where the $ stuff is documented, holler please. I had a look through but couldn't find it.
Apologies, my response was based on authoring a survey using XLSForm but I downloaded the survey as an XForm and this question:
| type | name | label |
| note | my_note | lorem ${word_1}. ${word_2}. ${word_3}. ipsum |
is turned into:
<input ref="/dataInNotes/my_note">
<label>lorem <output value=" /dataInNotes/data_input/word_1 "/>. <output value=" /dataInNotes/data_input/word_2 "/>. <output value=" /dataInNotes/data_input/word_3 "/>. ipsum</label>
</input>
(where dataInNotes
is the survey form name)
Does that help?
See also this survey and using-responses.xml (2.3 KB)
| type | name | label | appearance | calculation |
| begin group | name | | field-list | |
| text | last | Last name | | |
| text | first | First name | | |
| end group | | | | |
| integer | age | Age (years) | | |
| calculate | concat_data | | | concat(${first}," ",${last}," (",${age}," years old)") |
| note | note | ${last}, ${first} (${age} years old) | | |
| note | note_concat | ${concat_data} | | |
Thank you again. This is immensely helpful!
