It is very urgent, please help me.
How to prevent of duplicate data entry in the same device?
Suppose, I have completed data entry for a household, whose 'HouseholdID' is 'HA001'. and again I mistakenly entry data for the same household with 'HouseholdID' is 'HA001'.
Is it possible to restrict the duplicate HouseholdID in the same device.
Let me know, how can I prevent it.
unfortunately it's not possible to do that. There is now way to check previous answers for the same question in saved forms.
Hi. Is this still not possible?
Thanks.
Here's what you can do:
- Detect and prevent duplicates across repeat instances in one form: Avoiding duplicate selection in repeat group - #22 by LN
- Use
last-saved
in a similar way to prevent duplicates across local submissions of the same form: Deactivate option if selected once - #3 by ahblake (be sure to read about limitations) - Use the entity preview or an attached CSV updated based on previously-submitted data to prevent duplicates across all submitted data (requires devices being frequently online)
If you describe your workflow in more detail, there may be other ideas for you.
