I'm hoping someone who has been through this can help me figure out
what is wrong.
I already built my survey on Build. Seems fine...
Then I created a local instance of Aggregate.
But, there are several problems. If I try to export the survey to XML,
then upload on Aggregate, I get:
"Error: Problem with JavaRosa Parsing Form:null"
If I try to load the XML on a SD card and do it manually on the phone,
it says it can't read the file.
If I try to export directly to Aggregate (v.0.9.6) from Build, I get
"Internal Server Error"
It would appear there is something wrong with Build, or the survey I
made in it. But I'm not sure. Any advice? I followed the scanty
instructions I could find on the website. I am not a developer, but
need to evaluate whether ODK is a solution for my company.
To answer the question can you send a copy of the form as it's hard to
answer without seeing the form.
Can you either file an issue on our website with the form or use
Dpaste (http://dpaste.com/) to send a link of the form?
Waylon
On Tue, Jul 19, 2011 at 1:47 PM, Derek wrote:
> Hi everybody,
> what is wrong.
> Thanks in an advance to all who apply,
> Derek
Export to XML within ODK Build, copy -paste and create a new file with
extension .xml
Download and run Validate
Then validate the local file you created
If the file is valid and you still get this error, then the problem is
almost certainly not with the form.
While its possible Build created an invalid form, its probably in the
process of moving it to your desktop that you ran into the problem.
James
Hi everybody,
what is wrong.
