Problem in installing ODK aggregate
I am unable to install ODK aggregate
When I enter the application id, username and extraction of files is done for ODK aggregate, I click "Finish" in the dialogue box. Then the error occurs and the process is terminated.
ODK AGgregate v1.7.1. I am using it on Windows 10 Pro on HP device
I have tried with different user id and machine. The problem persists
Screenshot of error message attached
What version of Java are you running? In your Windows command prompt, write java -version and paste what you find.
And while you are in the command prompt, navigate to where the jar is and run java -jar ODKAggregateAppEngineUpdater.jar and report back what that says.
Hi, I am using Java 8.201 version. Whenever I am trying to upload ODK in the final step, the action gets aborted.
Hey you need Java 9 or above also I made one video of How to setup ODK Server.
Here is link of my video which will help you to install ODK Server.
@iamnarendrasingh
Hi, can you please share java 9 or above version. Checked on google. Couldn't find it.
Here is latest one. Youcan download Java from here.
https://www.oracle.com/technetwork/java/javase/downloads/index.html
@iamnarendrasingh
And if you're installing to App Engine, you should grab Aggregate v1.7.2!
And to be clear, Java 8 should be fine. We document the required versions at https://docs.opendatakit.org/aggregate-deployment-planning/#component-versions
I tried using the ODK v1.7.2 version as well with Java 8 but could not upload the ODK Aggregate. Please help.
