When attempting to distribute ODK Collect 1.25.1 to multiple managed Android 6.0.1 tablets the application fails to install (spins for a long time and returns a "Failed" message). The only thing that seems unusual on the AirWatch side is that the ODK Collect version number is not read correctly. AirWatch takes the version number from code but reports that the first digit (octet?) is null. If I do not force a "1" in the first position AirWatch will display the version as "0.25.1" Other than that, there's nothing unusual. Side-loading works OK.
AirWatch ver: 19.7.0.20 (1907)
ODK Collect ver: 1.25.1
Android ver: 6.0.1
Mobile Device: Samsung Tab A; 16 GB memory
Removed earlier versions of ODK Collect from the server and removed from a test tablet.
Added a new device to the assignment group in order to have a device w/ no prior installations.
Both had the same "Failed" result.
W/out an AirWatch installation I can't imagine one could reproduce the problem. Rather, I'd like to be reassured that this build is versioned correctly. We have a help ticket open w/ AirWatch and I'd like to be able to assure them that the app is OK. or, if someone has had a similar experience get some advice.
I got nothin'.
