i created a simple form where we have:
a question with 3 options and the last one is a other option, all displayed
in a unique page.
if you select Other option a text field is displayed.
So i downloaded and installed the last ODK app and i uploaded the form
(attached)...
the problem is:
if i select Other i need to swipe right the page and then re-swipe back the
app to see the text field...
Question: is not possible to show the text field immediately when the other
option is selected?
Thank you very much
Angelo
test.xml (1.76 KB)
Angelo,
It's a limitation in Collect and it's documented at
https://opendatakit.org/help/form-design/workarounds/. Move the other to
the next page.
Need ODK services? http://nafundi.com provides form design, server setup,
professional support, and software development for ODK.
On Mon, Jul 13, 2015 at 5:00 AM, Angelo Lazzari lazzari.angelo@gmail.com wrote:
displayed in a unique page.
(attached)...
the problem is:
the app to see the text field...
other option is selected?
Thank you very much
Angelo
