I try to install the odk aggregate on an amazon aws following the guide but I'm not able to login and test. I'm not sure about the page to check I found something on the internet but continues to charge and nothing happens.
Server is the aws t2.micro, with tomcat version 8.5.32 and mysql version 5.5.62 and odk agggregate 2.0.2
I try to do againg all the step on a new server, but the same results
All the ones that are in the guide on the documentation https://docs.opendatakit.org/aggregate-aws/
I not so able to find this file but I can provide anything is needed, sorry.
Welcome to the forum, @lorenzostucchi! When you get a chance, please introduce yourself here. I'd also encourage you to add a real picture as your avatar because it helps build community.
The Aggregate AWS instructions were a bit out of date and we just updated them. It may take a few hours for it to show up on the website, but can you revisit https://docs.opendatakit.org/aggregate-aws/ and give it another try?
You'll know you have the correct instructions if you see something like this:
Thanks @yanokwa, I will try later, thanks for the reply.
Hi @yanokwa, I try to apply the guide but I'm not able to enable the https, and I'm not able to download the blank form in the odk collect app, can be related with the problem with https?
Thanks again for the helpful new guide
Glad the guide is working for you!
Did you link the domain name to the machine's IP address? What happens when you run the enable HTTPS instructions at https://docs.opendatakit.org/aggregate-aws/#enable-https?
Yes, I follow all the procedure into the guide. In the screenshot there is the error that I have from the aws server try to done the command.
Are you sure you've properly configured your domain? Here's what it should look like in FreeDNS.
Ok I solve the problem, I have to put on the destination the public ip of my amazon web services instances, this was not clear to me, I think that this should be putted inside the guide
@lorenzostucchi I've attached a screenshot of the current documentation. As you can see, Step 2 says "Take note of the IPv4 Public IP address". What specific language would you like to change?
Probably can be good to explicitly also in the details.
After the:
... we recommend using FreeDNS to get a free sub-domain.
Add somethings like:
In freedns setting add your IPv4 Public IP address as destination.
I think that this make all more simple, thanks for your reply and the help.
Puedo cambias https a http nada más
Hi Yanokwa, My name is Osman, I am voluntary in Mexican red cross , I have a problem with ODK aggregate installation, I am installing ODK aggregate with amazon web services,
I have already done all the steps but in the my web site still appear welcome to nginx, help me pls.
habre un nuevo hilo explicando completamente todo tu error, muchos hemos pasado ya por esa situacion. si se te complica podrias intentar con Digital ese se me hizo mas facil y me ayudo a poder instalarlo sin problemas en amazon
