Hi all!
I tried making a quick form in build and exporting it from build to
aggregate but i keep getting a vague error message. Any idea what is going
on? Thanks for the help!
-Sarah Pfeil
Hi Sarah,
For the community to help, you need to be very specific about the
steps you are taking and what the precise error message is.
-- Need ODK help? Go to http://nafundi.com for custom features, form design, implementation support, and user training for ODK.On Wed, May 29, 2013 at 11:01 AM, Sarah Pfeil skpfeil@gmail.com wrote:
Hi all!
-Sarah Pfeil--
You need to:
(1) create a Google AppEngine application id ("ugilase") -- which you did.
(2) download the ODK Aggregate installer and follow the 'Installing on
Google AppEngine' instructions here:
http://opendatakit.org/use/aggregate/run it, specifying the '
On Wed, Jun 12, 2013 at 7:29 AM, wrote:My problem is similar (if I understood well). I just created a test form
with http://build.opendatakit.org/, saved it, and then clicked on
"Publish to Aggregate..." option. In the "Export" pop-up, I wrote "ugilasi"
into the "Aggregate Instance URI" field, and clicked on "export" button.
Which guides me to the webpage http://build.opendatakit.org/aggregate/postwith the message "Not Found
". Sometimes I get the "Internal Server
error" message.After the first error, I went to Google APP Engine and create the app with
the same name ("ugilase"); just in case... But without success.Now I'm reading some docs to see where's my mistake. In the meantime, any
help will be welcome.Thanks in advance.
urgh...
and then you will be able to publish from build into that ODK Aggregate.
On Wed, Jun 12, 2013 at 11:02 AM, Mitch Sundt wrote:You need to:
Google AppEngine' instructions here: http://opendatakit.org/use/aggregate/run it, specifying the 'On Wed, Jun 12, 2013 at 7:29 AM, ugilasi@gmail.com wrote:
http://build.opendatakit.org/aggregate/post with the message "Not
". Sometimes I get the "Internal Server error" message.
FoundAfter the first error, I went to Google APP Engine and create the app
with the same name ("ugilase"); just in case... But without success.Now I'm reading some docs to see where's my mistake. In the meantime, any
