To complete the installation,
I browsed to C:\odk\ODK Aggregate I double click uploadAggregateToAppEngine.hta to deploy ODK Aggregate up into Google's AppEngine cloud. This script ask for the email account with the administrative rights for my appspot instance and the password for that account. I type my gmail account and the password of my gmail account. It starts to deploy like following:
Looking for java...
found java in PATH... C:\Program Files\Java\jdk1.7.0_67\bin\java.exe
Sep 08, 2014 3:30:31 PM com.google.appengine.tools.info.RemoteVersionFactory getVersion
INFO: Unable to access https://appengine.google.com/api/updatecheck?runtime=java&release=1.9.7×tamp=1404188017&api_versions=['1.0']
java.net.ConnectException: Connection timed out: connect
at java.net.DualStackPlainSocketImpl.connect0(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:579)
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:618)
at sun.security.ssl.BaseSSLSocketImpl.connect(BaseSSLSocketImpl.java:160)
at sun.net.NetworkClient.doConnect(NetworkClient.java:180)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:432)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:527)
at sun.net.www.protocol.https.HttpsClient.(HttpsClient.java:275)
at sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:371)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:191)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:932)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:177)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1300)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getInputStream(HttpsURLConnectionImpl.java:254)
at java.net.URL.openStream(URL.java:1037)
at com.google.appengine.tools.info.RemoteVersionFactory.getVersion(RemoteVersionFactory.java:76)
at com.google.appengine.tools.info.UpdateCheck.getApplicationVersionInfo(UpdateCheck.java:153)
at com.google.appengine.tools.info.UpdateCheck.maybePrintNagScreen(UpdateCheck.java:361)
at com.google.appengine.tools.admin.AppCfg.(AppCfg.java:185)
at com.google.appengine.tools.admin.AppCfg.(AppCfg.java:124)
at com.google.appengine.tools.admin.AppCfg.main(AppCfg.java:120)
Reading application configuration data...
Sep 08, 2014 3:30:31 PM com.google.apphosting.utils.config.AppEngineWebXmlReader readAppEngineWebXml
INFO: Successfully processed C:/odk/ODK Aggregate/ODKAggregate\WEB-INF/appengine-web.xml
Sep 08, 2014 3:30:31 PM com.google.apphosting.utils.config.AbstractConfigXmlReader readConfigXml
INFO: Successfully processed C:/odk/ODK Aggregate/ODKAggregate\WEB-INF/web.xml
INFO: Successfully processed C:/odk/ODK Aggregate/ODKAggregate\WEB-INF/cron.xml
INFO: Successfully processed C:/odk/ODK Aggregate/ODKAggregate\WEB-INF/queue.xml
Sep 08, 2014 3:30:31 PM com.google.apphosting.utils.config.IndexesXmlReader readConfigXml
INFO: Successfully processed C:/odk/ODK Aggregate/ODKAggregate\WEB-INF/datastore-indexes.xml
INFO: Successfully processed C:/odk/ODK Aggregate/ODKAggregate\WEB-INF/backends.xml
Beginning interaction for module default...
0% Rolling back the update.
Unable to rollback app: Connection timed out: connect
Please see the logs [C:\Users\ICRAF\AppData\Local\Temp\appcfg5346434313601086688.log] for further information.
---- WEBSITE COMPLETE - BEGIN BACKEND ----
Sep 08, 2014 3:31:14 PM com.google.appengine.tools.info.RemoteVersionFactory getVersion
Sep 08, 2014 3:31:14 PM com.google.apphosting.utils.config.AppEngineWebXmlReader readAppEngineWebXml
Sep 08, 2014 3:31:14 PM com.google.apphosting.utils.config.AbstractConfigXmlReader readConfigXml
Sep 08, 2014 3:31:14 PM com.google.apphosting.utils.config.IndexesXmlReader readConfigXml
Warning: This application uses Backends, a deprecated feature that has been replaced by Modules, which offers additional functionality. Please convert your backends to modules as described at: https://developers.google.com/appengine/docs/java/modules/converting.
0% Rolling back the update on backend background.
Please see the logs [C:\Users\ICRAF\AppData\Local\Temp\appcfg2675745008834086421.log] for further information.
---END-SCRIPT-SUCCESS---
After this to get to ODK Aggregate
Visiting http://my-app-id.appspot.com/
where I put my-app-id = , like http://.appspot.com/
results no data received. I can not access ODK Aggregate.
