I'm new at using ODK and was able to use it successfully. I had to change a few things on the survey. I am now having problems uploading the xml forms onto ODK Aggregate. This is the message that pops up. I'm not sure whether this is due to the changes to the survey or if I'm missing something. Thanks for your help.
Problem persisting data or accessing data org.opendatakit.common.persistence.exception.ODKEntityPersistException: org.springframework.dao.DataAccessResourceFailureException: PreparedStatementCallback; SQL [INSERT INTO "odk_pnash_new"."_form_info_xform_blb" ( "_URI", "_CREATOR_URI_USER", "_CREATION_DATE", "_LAST_UPDATE_URI_USER", "_LAST_UPDATE_DATE", "_TOP_LEVEL_AURI", "VALUE" ) VALUES ( ?, ?, ?, ?, ?, ?, ? ) ]; ERROR: could not extend relation base/29895/30876: No space left on device Hint: Check free disk space.; nested exception is org.postgresql.util.PSQLException: ERROR: could not extend relation base/29895/30876: No space left on device Hint: Check free disk space.
