I have a similar issue when using kobo in combination with enketo. I have followed the "birds" example from http://xlsform.org/en/#media that is also used by kobohelp (http://help.kobotoolbox.org/creating-forms/advanced/adding-media-to-your-form)
I have uploaded the files to kobo (under settings -> add document) and still, it does not display the pictures. I also tried to simply display a picutre as a note, which also did not work.
Here is my example:
https://docs.google.com/spreadsheets/d/1OKlf0oX3UZIFy-RgQBJtFmM0ICh0cbLQut6wgYqvjbI/edit?usp=sharing
Support questions about Kobo should go to the Kobo team at http://help.kobotoolbox.org .
I was not sure if this just relates to Kobo, Enketo or is a general issue, but I have written them a message
I think it is probably KoBo. But you could have a look at https://enke.to/::widgets (link to source at top) in case there is a syntax issue.
thx again for your quick responses in this forum!
I checked the syntax several times now (even asked a colleauge to cross check). Everything is correct.
Waiting for a response from Kobo, but it seems that their support is not as active atm.
