When take a geoshape, if the screen locks while walking the GPS tracks are not ok. With the same phone, it works perfectly is the screen stays unlocked. It seems to be linked to the device, as for other devices the GPS tracks keeps working.
Is there a specific parameter?
ODK Collect version 2022 1.2
Samsung
Kobo server
We made some test, not locking the screen
Hi @Emma_Joseph_Oudin
Welcome to the ODK forum. We're glad you're here. When you get a chance, please introduce yourself on this forum thread. I'd also encourage you to add a picture as your avatar because it helps build community!
What do you mean by that? The process is stopped or wrong data is saved?
What's the model? You just said it's Samsung. And what android version?
Hi @Grzesiek2010 , thanks for your answer.
In the meantime, we learnt that the phone itself had a problem that could probably explain the wrong data we had.
Can you please confirm that locking the screen should not have an impact on GPS tracking?
Thanks again!
Emma
Yes as long as you use Collect v2021.2.0 or newer Geoshape/geotraces should work in the background or with screen locked, see: ODK Collect v2021.2
