I have got to step 17 on the Aggregate Installation page. I get the following error: Unknown error: There has been an error while running java -jar.\ODKAggregateAppEngineUpdater.jar The application will exit now
v1.6.1 on Windows 10
I think it's something to do with Java but I don't understand Java or any programming enough to use initiative when it comes to problem solving. If I could be walked through step by step how to fix it that would be great.
Googled it. A couple of similar errors came up and one suggested that the problem was Java, but I don't know how to connect that with the fix
