Problem with Aggregate
Mitch,
I've got an error with Aggregate (v1.2.0 Production) .
I was able to upload several forms, use them on Collect, and then publish
the data to FusionTables.
As I iterate on the forms, I am deleting old ones and deleting the
publish.
I typically create the agg instance using one account and then use publish
from another. So, I open firefox for one and chrome for the other user.
Now, when I try to upload a form with the app owner's google credentials, I
get the typical "A problem has occurred that prevents your AppEngine
application from responding. Your application may have exceeded its
per-minute or daily usage quotas. blab"
I looked at my quotas and I wasn't anywhere close as I'm using this for
testing and then demo.
Anyway, I then added a payment account just to be safe.
The only critical error I see in the logs is
  1. C 2012-08-13 18:01:24.869 Uncaught exception from servlet
    org.javarosa.xform.parse.XFormParseException: ERROR: Control binding
    [/data/date_time] matches no nodes at org.javar
I believe this was from a Form that I subsequently deleted, to correct the
name.
I hope you don't mind but I'll add you as a dev.
··· -- James Dailey skype: jdailey
Please ignore. Bad form. I should definitely follow the procedure of
checking the form with Validator first. Sorry about that.
··· On Mon, Aug 13, 2012 at 6:08 PM, James Dailey wrote:
Mitch,
publish.
I get the typical "A problem has occurred that prevents your AppEngine
name.
James Dailey
skype: jdailey
James Dailey
skype: jdailey
