Problem with calculate expressions for area in v1.16.0
I can not load a form that has the calculate function area(). An error is thrown when I try to open the form for filling.
I am using ODK Collect version v1.16.0(latest version). I am using a Samsung Galaxy Tablet - Galaxy Tab A(2016), Model Number - SM-T280. Android version - 5.1.1
Download the attached test form on ODK Collect. Click on Fill Blank Form then click on the form.
I tried loading the same form on older versions of ODK Collect and it opened just fine. I was able to fill in data and submit a few records. I tried the following versions; v1.15.1, v1.15.0, v1.14.1, v1.14.2
Error returned Screenshot_072518_031655_PM
Test form
Hi @kaymutua
thank you very much for reporting this issue, it's indeed a bug in the Javarosa. As a workeround for now you can change your calculation to: if((${shape1}=null), 0, area(${shape1})) we will try to fix the issue and realease a new version of ODK Collect.
Thank you @Grzesiek2010 for the workaround.
Thanks so much for reporting this right away @kaymutua and for the quick action, @Grzesiek2010! v1.16.1 has the fix and is currently rolling out.
Great, Thank you for the quick fix @LN
