I am running ODK Central on a Digital Ocean droplet.
I followed the steps for Central upgrade and everything seemed to go smoothly.
When I try to log-in on my domain, I receive a message
"A user is already logged in. Please refresh the page to continue."
When I try to download data via ruODK, I get the following error message:
se <- submission_export(local_dir="odk_exports", overwrite=TRUE, media=FALSE)
Request failed [502]. Retrying in 1.2 seconds...
Request failed [502]. Retrying in 2.1 seconds...
Error in response %>% httr::stop_for_status(task = glue::glue("get desired response from server {url} as user "{un}".\n\n", :
Bad Gateway (HTTP 502). Failed to get desired response from server https://libodk.com as user "nicholai@lib.solar"
Here is the version info from version.txt:
cd751d789e35e5cb1469cf651d6ba7275903bc03 (v1.4.2-4-gcd751d7)
461c1037997f9fb88075b75612b83cea297ced42 client (v1.4.0)
367a7f572d3ede411cea16d0fa1decb98e280e92 server (v1.4.2)
When I check the status using docker-compose ps
, everything seems fine:
root@odk:~/central# docker-compose ps
Name Command State Ports
central_enketo_1 docker-entrypoint.sh /bin/ ... Up 8005/tcp
central_enketo_redis_cache_1 docker-entrypoint.sh redis ... Up 6379/tcp
central_enketo_redis_main_1 docker-entrypoint.sh redis ... Up 6379/tcp
central_mail_1 /bin/entrypoint.sh exim -b ... Up 25/tcp
central_nginx_1 /bin/bash /scripts/odk-set ... Up (healthy) 0.0.0.0:443->443/tcp,
0.0.0.0:80->80/tcp
central_postgres_1 docker-entrypoint.sh postgres Up 5432/tcp
central_pyxform_1 gunicorn --bind 0.0.0.0:80 ... Up
central_secrets_1 docker-entrypoint.sh ./gen ... Exit 0
central_service_1 docker-entrypoint.sh ./wai ... Up 8383/tcp
Here is an excerpt from the nginx logs, which shows errors due to connection refused.
2022/04/20 18:47:09 [error] 199#199: *123 connect() failed (111: Connection refused) while connecting to upstream, client: 69.209.6.149, server: libodk.com, request: "GET /v1/sessions/restore HTTP/1.1", upstream: "http://172.18.0.8:8383/v1/sessions/restore", host: "libodk.com", referrer: "https://libodk.com/"
69.209.6.149 - - [20/Apr/2022:18:47:09 +0000] "GET /v1/sessions/restore HTTP/1.1" 502 568 "https://libodk.com/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.88 Safari/537.36"
69.209.6.149 - - [20/Apr/2022:18:47:09 +0000] "GET /fonts/icomoon.ttf?ijnc2n HTTP/1.1" 304 0 "https://libodk.com/css/app.e22ccca1.css" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.88 Safari/537.36"
69.209.6.149 - - [20/Apr/2022:18:47:09 +0000] "GET /favicon.ico HTTP/1.1" 304 0 "https://libodk.com/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.88 Safari/537.36"
69.209.6.149 - - [20/Apr/2022:18:47:24 +0000] "GET /version.txt HTTP/1.1" 304 0 "https://libodk.com/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.88 Safari/537.36"
2022/04/20 18:47:30 [error] 199#199: *191 connect() failed (111: Connection refused) while connecting to upstream, client: 41.191.107.44, server: libodk.com, request: "GET /v1/key/1234/projects/2/formList HTTP/1.1", upstream: "http://172.18.0.8:8383/v1/key/1234/projects/2/formList", host: "libodk.com"
41.191.107.44 - - [20/Apr/2022:18:47:30 +0000] "GET /v1/key/1234/projects/2/formList HTTP/1.1" 502 166 "-" "org.odk.collect.android/v2021.2.4 Dalvik/2.1.0 (Linux; U; Android 11; TECNO PR651H Build/RP1A.201005.001)"
192.241.206.190 - - [20/Apr/2022:18:47:34 +0000] "GET /portal/redlion HTTP/1.1" 301 185 "-" "Mozilla/5.0 zgrab/0.x"
2022/04/20 18:48:17 [error] 199#199: *196 connect() failed (111: Connection refused) while connecting to upstream, client: 69.209.6.149, server: libodk.com, request: "GET /v1/test/ABCD/projects/2.forms/RegistrationCentral3/draft/formList HTTP/1.1", upstream: "http://172.18.0.8:8383/v1/test/ABCD/projects/2/forms/RegistrationCentral3/draft/formList", host: "libodk.com"
69.209.6.149 - - [20/Apr/2022:18:48:17 +0000] "GET /v1/test/ABCD/projects/2/forms/RegistrationCentral3/draft/formList HTTP/1.1" 502 166 "-" "org.odk.collect.android/v2022.2.0 Dalvik/2.1.0 (Linux; U; Android 11; SM-A725M Build/RP1A.200720.012)"
69.209.6.149 - - [20/Apr/2022:18:48:24 +0000] "GET /version.txt HTTP/1.1" 304 0 "https://libodk.com/" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.88 Safari/537.36"
Here is an excerpt from docker logs --tail 100 central_service_1
, which shows migration issues:
generating local service configuration..
running migrations..
(node:27) UnhandledPromiseRejectionWarning: error: the database system is starting up
at Parser.parseErrorMessage (/usr/odk/node_modules/pg-protocol/dist/parser.js:278:15)
at Parser.handlePacket (/usr/odk/node_modules/pg-protocol/dist/parser.js:126:29)
at Parser.parse (/usr/odk/node_modules/pg-protocol/dist/parser.js:39:38)
at Socket.<anonymous> (/usr/odk/node_modules/pg-protocol/dist/index.js:10:42)
at Socket.emit (events.js:400:28)
at Socket.emit (domain.js:470:12)
at addChunk (internal/streams/readable.js:290:12)
at readableAddChunk (internal/streams/readable.js:265:9)
at Socket.Readable.push (internal/streams/readable.js:204:10)
at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
(Use `node --trace-warnings ...` to show where the warning was created)
(node:27) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 5)
(node:27) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
checking migration success..
*** Error starting ODK! ***
After attempting to automatically migrate the database, we have detected unapplied migrations, which suggests a problem with the database migration step. Please look in the console above this message for any errors and post what you find in the forum: https://forum.getodk.org/
I have tried restarting the droplet,
I've tried systemctl stop docker-compose@central
followed by docker-compose build
I've confirmed that there is enough disk space using df -h
I've created a new administrator account with a different email / login but get the same error.
I tried installing docker-compose based on instructions here:
So now I am on docker-compose version 1.29.2
I noticed that my .env didn't have port instructions, so I modified it like this:
SSL_TYPE=letsencrypt
DOMAIN=libodk.com
SYSADMIN_EMAIL=nicholai@lib.solar
HTTP_PORT=80
HTTPS_PORT=443
I tried increasing the memory allocation following the instructions here:
https://docs.getodk.org/central-install-digital-ocean/#central-install-custom-memory
I used - NODE_OPTIONS=--max_old_space_size=6144
since I have 8GB available.
This seems to have fixed the migration problem but the main issues remain.
Any help would be very much appreciated.
Thank you,
Nicholai
