Problem with GPS shape and line modification in Enketo
We collect data with ODK Collect, then we load this data into KoboToolbox and edit this data with Enketo from Kobotoolbox.
The problem is with geoshape data.
When we try to edit them with Enketo, there are more points that appear on screen than we have really collected. So it takes much more time to check and edit each answers.
This is what I have of my phone :
Then I’ve immediately downloaded the data from Kobo to XLS and got :
48.81420163186936 2.378957122564316 0.0 0.0;48.81329421655844 2.3803019151091576 0.0 0.0;48.812516387392996 2.378598041832447 0.0 0.0;48.8135615856475 2.377382330596447 0.0 0.0;48.81420163186936 2.378957122564316 0.0 0.0;
(with “;” at the end)
Then I went to editing mode with Enketo :
enketo_point1
enketo_point_2 enketo_point_3 enketo_point_4 enketo_point_5 enketo_point_6
Then I’ve clicked on “close polygon” and got :
48.81420163186936 2.378957122564316 0 0;48.81329421655844 2.3803019151091576 0 0;48.812516387392996 2.378598041832447 0 0;48.8135615856475 2.377382330596447 0 0;48.81420163186936 2.378957122564316 0 0;48.81420163186936 2.378957122564316 0 0
(so without “;” at the end)
Finally I’ve downloaded the data again on XLS and got :
(Still without “;” at the end)
I use ODK collect (V1.29.5) and Kobotoolbox server for "Researchers, Aid Workers & Everyone Else"
I have reported this problem to kobotoolbox support and the noticed the problem with th ";" at the end and advised me to report it here.
The steps that are described above.
Thank you a lot
Fabien
The ideal would be for Enketo to be robust to trailing semicolons because they have always existed at the end of traces and shapes produced by Collect. New versions of Collect can stop producing them but there will continue to be many submissions with this structure. @martijnr does that seem reasonable? If so it might be something I can look at in the Enketo implementation.
No, sorry that would not be a good idea as the code changes required are not insignificant and somewhat silly because of Enketo's architecture. I looked at doing this, and actually mostly finished implementing it, after which I discarded the code. Thanks for offering though. Best to get rid of the trailing semi-colons in new versions of Collect.
:+1: I agree that the issue is best fixed at the source: delimiters [sic] shouldn't strictly appear at the end (or beginning!), and having them there is rather open to interpretation... (think multiple commas at end of CSV).
Sad to hear that! We’ve left it alone because inevitably the change will break some folks’ bespoke downstream analysis. It’s typically not a big deal for general-purpose tools to support. Now that we have a counter example we’ll announce the change for Collect v1.31. Hopefully anything that does break will be easy to fix.
