Problem with polygon collection
cordial greetings I write from Colombia, we have been handling Odk for about 5 years, the version 1.22.1 that we are using we found a fault to take polygons, since they suggest changing geotrace by geoshape, but this does not capture the coordinates well when the equipment is it disables the screen. What would be relevant to take batches of more than 1 has)
Hi @audi
what do you mean? Is it the case where you use the automatic mode? Please describe your problem more carefully.
Explicame bien el problema, a ver si puedo ayudarte
Saludos el tema es que cuando medimos lotes con Odk de manera automatica o manual hay que dejar la pantalla habilitada o si no pegas las coordenadas en el mismo punto.
