Problem with regex
Hello everybody
I have a validation with regex in the constraint of the form since it works correctly in the file in the online test environment (https://getodk.org/xlsform/) but being in the latest version of ODK Collect 1.27.1 it does not work .
The conditions are as follows: regex (., '[A-Z]') and regex (., '[A-ZA-Z]')
Aggregate 1.7.3 y ODK Collect 1.27.1
NA
I attach the test file with the question
test.xlsx (187.5 KB)
Can you perhaps describe what constraint you are attempting to enforce? eg a specific string that should match vs one that should fail... FYI the ones above will check for the presence (one or more occurances) of an uppercase letter in your string.
FYI, you should probably be aware that there is a slightly different behavior wrt the regex() function between Collect and Enketo; documented here: https://github.com/getodk/javarosa/issues/531
Net is that you should probably include the ^ (start string) and $ (end string) delimiters in your regex expression, otherwise it'll match any substring - depending on what XForm client you use... So, for example, if you want to make sure a string contains only uppercase characters, try:
regex(., '^[A-Z]*$')
Thanks for the help, indeed they were the limiters of the regex
