Hi! I create a survey using excel and I'm trying to use begin repeat and calculate in type column but when I try to convert my excel file to json file by XLXSForm Converter in Application Designer v.2, it display an "Unrecognized prompt type. Prompt: 'begin repeat' " same goes with the calculate. I follow the XLSForm design in XLSForm.org. Is there anything I miss? Thank you very much
The documentation for how to create an xlsx file that is compatible with
the XLSX Converter in the ODK 2.0 Application Designer can be found at
https://opendatakit.org/use/2_0_tools/active-distribution/odk-application-designer-2-0-rev200/odk-xlsxconverter-2-0-rev200/.
The output from the XLSX Converter is used to create a form that can be
used with ODK Survey.
The directions at XLSForm.org are for creating a form that can be used with
ODK Collect.
Clarice
On Fri, May 13, 2016 at 10:42 AM, wrote:Hi! I create a survey using excel and I'm trying to use begin repeat and
miss? Thank you very much--
i.e., There are two different sets of incompatible tools:
ODK 1.x tools: (XML-based; document-based)
XLSForm ( xlsform.org )
ODK Collect
ODK Validate
ODK Briefcase
ODK Aggregate
ODK Form Uploader
ODK 2.0 tools: (JSON-based; database-table-based)
App Designer (e.g, XLSX Converter)
ODK Survey
ODK Tables
ODK Services
ODK Scan
ODK Suitcase
ODK Aggregate with ODK Tables extensions
============== Choose the set that works for your needs; that usually means ODK 1.x.The ODK 2.0 tools are not yet supported for general use.
used with ODK Survey.The directions at XLSForm.org are for creating a form that can be used
with ODK Collect.Clarice
Thank you very much clarice larson, Now I have gone through the
documentation and I didn't found the repeat prompt type or how to create a
loop with questions. So I cannot use a repeat or making a loop in XLSX
Convertor? Is there any other way around?
เมื่อ วันเสาร์ที่ 14 พฤษภาคม ค.ศ. 2016 1 นาฬิกา 04 นาที 44 วินาที UTC+7,
clarice larson เขียนว่า:
> > The documentation for how to create an xlsx file that is compatible with > the XLSX Converter in the ODK 2.0 Application Designer can be found at > https://opendatakit.org/use/2_0_tools/active-distribution/odk-application-designer-2-0-rev200/odk-xlsxconverter-2-0-rev200/. > The output from the XLSX Converter is used to create a form that can be > used with ODK Survey. > > The directions at XLSForm.org are for creating a form that can be used > with ODK Collect. > > Clarice > > On Fri, May 13, 2016 at 10:42 AM, <wara...@gmail.com > wrote: > >> Hi! I create a survey using excel and I'm trying to use begin repeat and >> calculate in type column but when I try to convert my excel file to json >> file by XLXSForm Converter in Application Designer v.2, it display an >> "Unrecognized prompt type. Prompt: 'begin repeat' " same goes with the >> calculate. I follow the XLSForm design in XLSForm.org. Is there anything I >> miss? Thank you very much >> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/d/optout. >> > >Thank you Mitch Sundt, Now I know I have misunderstood the whole tools
version. However I already setup an ODK Aggregate server and trying to use
ODK Survey to collect the data. But do I have to install additional ODK
Tables extensions that you mentions?
เมื่อ วันเสาร์ที่ 14 พฤษภาคม ค.ศ. 2016 2 นาฬิกา 25 นาที 29 วินาที UTC+7,
Mitch Sundt เขียนว่า:
> > i.e., There are two different sets of *incompatible* *tools*: > > ODK 1.x tools: (XML-based; document-based) > XLSForm ( xlsform.org ) > ODK Collect > ODK Validate > ODK Briefcase > ODK Aggregate > ODK Form Uploader > > ODK 2.0 tools: (JSON-based; database-table-based) > App Designer (e.g, XLSX Converter) > ODK Survey > ODK Tables > ODK Services > ODK Scan > ODK Suitcase > ODK Aggregate with ODK Tables extensions > > ============== > Choose the set that works for your needs; that usually means ODK 1.x. > > The ODK 2.0 tools are not yet supported for general use. > > > On Fri, May 13, 2016 at 11:04 AM, clarice larson <clar...@gmail.com > wrote: > >> The documentation for how to create an xlsx file that is compatible with >> the XLSX Converter in the ODK 2.0 Application Designer can be found at >> https://opendatakit.org/use/2_0_tools/active-distribution/odk-application-designer-2-0-rev200/odk-xlsxconverter-2-0-rev200/. >> The output from the XLSX Converter is used to create a form that can be >> used with ODK Survey. >> >> The directions at XLSForm.org are for creating a form that can be used >> with ODK Collect. >> >> Clarice >> >> On Fri, May 13, 2016 at 10:42 AM, <wara...@gmail.com > wrote: >> >>> Hi! I create a survey using excel and I'm trying to use begin repeat and >>> calculate in type column but when I try to convert my excel file to json >>> file by XLXSForm Converter in Application Designer v.2, it display an >>> "Unrecognized prompt type. Prompt: 'begin repeat' " same goes with the >>> calculate. I follow the XLSForm design in XLSForm.org. Is there anything I >>> miss? Thank you very much >>> >>> -- >>> -- >>> Post: opend...@googlegroups.com >>> Unsubscribe: opendatakit...@googlegroups.com >>> Options: http://groups.google.com/group/opendatakit?hl=en >>> >>> --- >>> You received this message because you are subscribed to the Google >>> Groups "ODK Community" group. >>> To unsubscribe from this group and stop receiving emails from it, send >>> an email to opendatakit...@googlegroups.com . >>> For more options, visit https://groups.google.com/d/optout. >>> >> >> -- >> -- >> Post: opend...@googlegroups.com >> Unsubscribe: opendatakit...@googlegroups.com >> Options: http://groups.google.com/group/opendatakit?hl=en >> >> --- >> You received this message because you are subscribed to the Google Groups >> "ODK Community" group. >> To unsubscribe from this group and stop receiving emails from it, send an >> email to opendatakit...@googlegroups.com . >> For more options, visit https://groups.google.com/d/optout. >> > > > > -- > Mitch Sundt > Software Engineer > University of Washington > mitche...@gmail.com >Hi Warat,
The way that "Repeat groups" are used has changed in ODK 2.0 tools, but the
same functionality is still available. You define the repeated section as a
sub-form, and then link to that from your main form.
Here are quotes from the documentation:
------- Improved treatment of repeat-groups.* In the 2.0 tools, we have
eliminated the concept of a repeat-group. In its place, we provide prompts
that enable you to open and edit other surveys with links back to the
originating survey (if desired). These prompts can describe a sub-form
(nested) relationship among the surveys (e.g., household and
household-member) or they can represent arbitrary relational linkages
across your data (e.g., tea-houses and tea-types).
( https://opendatakit.org/use/2_0_tools/ )
See this link for details on how to do this:
https://opendatakit.org/use/2_0_tools/active-distribution/odk-application-designer-2-0-rev200/odk-xlsxconverter-2-0-rev200/#otherFeatures
Regards,
Andrew
Convertor? Is there any other way around?เมื่อ วันเสาร์ที่ 14 พฤษภาคม ค.ศ. 2016 1 นาฬิกา 04 นาที 44 วินาที UTC+7,
clarice larson เขียนว่า:The documentation for how to create an xlsx file that is compatible with
Hi Warat,
I found a bit more info under the following section:
https://opendatakit.org/use/2_0_tools/active-distribution/odk-application-designer-2-0-rev200/odk-xlsxconverter-2-0-rev200/#usingQueries
Scroll down to the paragraph beginning with "linked_table is the other use
for the queries worksheet"
Regards,
Andrew
On Monday, 16 May 2016 09:55:12 UTC+2, Andrew wrote: > > Hi Warat, > > The way that "Repeat groups" are used has changed in ODK 2.0 tools, but > the same functionality is still available. You define the repeated section > as a sub-form, and then link to that from your main form. > Here are quotes from the documentation: > ------ > > * Improved treatment of repeat-groups.* In the 2.0 tools, we have > eliminated the concept of a repeat-group. In its place, we provide prompts > that enable you to open and edit other surveys with links back to the > originating survey (if desired). These prompts can describe a sub-form > (nested) relationship among the surveys (e.g., household and > household-member) or they can represent arbitrary relational linkages > across your data (e.g., tea-houses and tea-types). > ( https://opendatakit.org/use/2_0_tools/ ) > > *See this link for details on how to do this:* > > https://opendatakit.org/use/2_0_tools/active-distribution/odk-application-designer-2-0-rev200/odk-xlsxconverter-2-0-rev200/#otherFeatures > > ---- > > Regards, > Andrew > > > > On Sunday, 15 May 2016 18:40:43 UTC+2, Warat Makapanich wrote: >> >> Thank you very much clarice larson, Now I have gone through the >> documentation and I didn't found the repeat prompt type or how to create a >> loop with questions. So I cannot use a repeat or making a loop in XLSX >> Convertor? Is there any other way around? >> >> เมื่อ วันเสาร์ที่ 14 พฤษภาคม ค.ศ. 2016 1 นาฬิกา 04 นาที 44 วินาที UTC+7, >> clarice larson เขียนว่า: >>> >>> The documentation for how to create an xlsx file that is compatible with >>> the XLSX Converter in the ODK 2.0 Application Designer can be found at >>> https://opendatakit.org/use/2_0_tools/active-distribution/odk-application-designer-2-0-rev200/odk-xlsxconverter-2-0-rev200/. >>> The output from the XLSX Converter is used to create a form that can be >>> used with ODK Survey. >>> >>> The directions at XLSForm.org are for creating a form that can be used >>> with ODK Collect. >>> >>> Clarice >>> >>> On Fri, May 13, 2016 at 10:42 AM, wrote: >>> >>>> Hi! I create a survey using excel and I'm trying to use begin repeat >>>> and calculate in type column but when I try to convert my excel file to >>>> json file by XLXSForm Converter in Application Designer v.2, it display an >>>> "Unrecognized prompt type. Prompt: 'begin repeat' " same goes with the >>>> calculate. I follow the XLSForm design in XLSForm.org. Is there anything I >>>> miss? Thank you very much >>>> >>>> -- >>>> -- >>>> Post: opend...@googlegroups.com >>>> Unsubscribe: opendatakit...@googlegroups.com >>>> Options: http://groups.google.com/group/opendatakit?hl=en >>>> >>>> --- >>>> You received this message because you are subscribed to the Google >>>> Groups "ODK Community" group. >>>> To unsubscribe from this group and stop receiving emails from it, send >>>> an email to opendatakit...@googlegroups.com. >>>> For more options, visit https://groups.google.com/d/optout. >>>> >>> >>>The ODK Tables extensions are built into ODK Aggregate, but you must enable
them on the Site Admin / Preferences page.
ODK 2.0 Features
ODK Tables Syncronization Functionality
ODK 2.0 Application Name
default
The Application Name used by the ODK 2.0 client application -- the name of
the Android directory under /sdcard/opendatakit.
On Mon, May 16, 2016 at 4:23 AM, Andrew wrote:Hi Warat,
for the queries worksheet"Regards,
AndrewOn Monday, 16 May 2016 09:55:12 UTC+2, Andrew wrote:
Hi Warat,
( https://opendatakit.org/use/2_0_tools/ )See this link for details on how to do this:
Regards,
with the XLSX Converter in the ODK 2.0 Application Designer can be found at
