I am having a problem uploading a from to my Local host and it is
giving me the following error
Problem accessing /upload. Reason:
Problem with JavaRosa Parsing Form:null
Help
before we can help, can you post the xml to dpaste.com and send out a link?
also, where did you get/make the form? did you try using odk validate to validate first? if you are using odk aggregate, what version are you using? what browser are you using to upload?
On Jun 2, 2011, at 5:39 PM, Keniajin wrote:I am having a problem uploading a from to my Local host and it is
Help
Thanks--
Hi! I have the same error message.
Here's my form, which I made using ODK Build: http://dpaste.com/549708/
I just tried ODK validate, and it gave me the following message:
"Checking form...
Parsing form...
Title: "REO_survey"
Select question has no choices
XForm is invalid. See above for the errors."
The version of ODK Aggregate I am using is v9.6
Browser: Google Chrome
Thanks!
On Jun 2, 7:58 am, Yaw Anokwa wrote: > before we can help, can you post the xml to dpaste.com and send out a link? > > also, where did you get/make the form? did you try using odk validate to validate first? if you are using odk aggregate, what version are you using? what browser are you using to upload? > > On Jun 2, 2011, at 5:39 PM, Keniajin wrote: > > > > > > > > > I am having a problem uploading a from to my Local host and it is > > giving me the following error > > Problem accessing /upload. Reason: > > Problem with JavaRosa Parsing Form:null > > Help > > Thanks > > > -- > > Post: opendatakit@googlegroups.com > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > > Options:http://groups.google.com/group/opendatakit?hl=enmaianna,
your addcorrect prompt is a select1, but it has no options. i've corrected it to a string and put the form at http://dpaste.com/549717/.
we'll try to add some validation in build so it warns you when select/select1 don't have options.
yaw
On Jun 2, 2011, at 7:38 PM, Maianna Voge wrote:Hi! I have the same error message.
"Checking form...
Parsing form...
Title: "REO_survey"
Select question has no choicesXForm is invalid. See above for the errors."
Browser: Google ChromeThanks!
Help
Thanks--
Options:http://groups.google.com/group/opendatakit?hl=en--
I made the form online at http://build.opendatakit.org/. and am using the
latest version of odk aggregate and am using Google Chrome and Mozilla
browser.
On Thu, Jun 2, 2011 at 5:58 PM, Yaw Anokwa wrote:before we can help, can you post the xml to dpaste.com and send out a
link?also, where did you get/make the form? did you try using odk validate to
what browser are you using to upload?On Jun 2, 2011, at 5:39 PM, Keniajin wrote:
Help
Thanks--
also, can you post a copy of the form at http://dpaste.com. without a copy of the form, we can't help.
On Jun 3, 2011, at 8:25 AM, Ken Mwai wrote:I made the form online at http://build.opendatakit.org/. and am using the latest version of odk aggregate and am using Google Chrome and Mozilla browser.
On Thu, Jun 2, 2011 at 5:58 PM, Yaw Anokwa yanokwa@gmail.com wrote:
before we can help, can you post the xml to dpaste.com and send out a link?also, where did you get/make the form? did you try using odk validate to validate first? if you are using odk aggregate, what version are you using? what browser are you using to upload?
Help
Thanks--
