I realise now i cannot set myself as a collector.oops. I have set up a new
user and can log in, but on the phone app obviously google account is set,
so even if I change the username and password to the new one set in the
aggregate, is that not a problem?
Thanks for your quick reply. I can now access the aggregate on google
apps (the email was indeed not identical in terms of uppercase/lowercase)
. However, when I access the aggregate site admin tab user options are
greyed out, I have no data collector for myself and cannot change anything.
I am unable to access the aggregate from my phone and was suspecting it was
to do with permissions. Although forms appear uploaded to the aggregate,
they are not visible when logged in.
apologies for all the questions...many thanks
On Wednesday, 8 August 2012 18:09:20 UTC+1, Mitch wrote:And w.r.t. your
attempt to use ODK Aggregate 1.2, when you specify your e-mail address
during the installer, you need to specify it exactly as reported by Gmail.
This generally means all-lowercase letters. To see the capitalization that
Gmail uses, click on your name in the upper right corner of Gmail. Use the
e-mail address reported under your name in the pop-up as the Superuser
e-mail address during the install.
On Wed, Aug 8, 2012 at 10:06 AM, Mitch S mitche...@gmail.com wrote:
Note that if your appspot instance is https://opendatakit.appspot.com,
in the Build dialog, you would enter just "opendatakit" in the field -- it
will prepend the https:// and the ".appspot.com" portion of the URL.
Also, you must sign up and log into Build before you can Publish a form
to aggregate, otherwise, you will get an {"error":"unauthenticated"}page
(Build needs to know your e-mail address in order to publish to Aggregate,
and it does this through your sign-in to Build).
You should confirm that the e-mail you specified in Build is appropriate
for your appspot instance. You can do this by clicking on the username in
the upper right corner of build. If you need to change that e-mail, you
can, but you will also need to re-enter your password, as clicking "Update"
apparently changes the password whether or not you enter your old
password. And the e-mail address change does not show immediately. You
have to log out, then log back into Build before the change to the e-mail
is applied. This is most likely the cause of your woes.
I've tried this with ODK Aggregate 1.2, and it works fine for me, so
this does not appear to be a problem with Build or Google AppEngine.
On Wed, Aug 8, 2012 at 8:33 AM, scrirmmager prbru...@gmail.com wrote:
when trying access the aggregate instance on app engine I get the
following errors, either invalid token (when trying to export forms to
aggregate from ODK build) or an invalid url when the app tries to redirect.
I was using the aggregate 1.0.9 because when using the latest version I
could not log into the aggregate using my google account details
I'd appreciate any help, best regards
