Exception in thread "main" java.lang.UnsupportedClassVersionError:
com/google/appengine/tools/admin/AppCfg : Unsupported major.minor version
51.0
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:637)
at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:283)
at java.net.URLClassLoader.access$000(URLClassLoader.java:58)
at java.net.URLClassLoader$1.run(URLClassLoader.java:197)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
---END-SCRIPT-FAILURE---
Press any key to close window . . .
Does anyone have knowledge of a solution to this problem?
Mike
Mike,
Search on this and the dev list for UnsupportedClassVersionError. I
don't remember the specifics, but it's generally an issue of not
having the right Java version installed (or pointed to)
On Wed, Mar 26, 2014 at 12:02 PM, Michael Stevens michael.stevens.miis@gmail.com wrote:
51.0
Mike
Hi group. I had a similar issue to some others in getting my computer to
point to the updated version of Java. Make sure you are installing the JDK
(developer's kit) rather than JRE (the reader). That solved my problem. You
will know you have the right version when the <java -version> prompt in
your terminal shows version 1.7.x or higher.
> 51.0
> Thanks,
> Mike
Thanks, Yaw. I just switched to an updated PC and am GTG now!
Best
Mike
On Wednesday, March 26, 2014, Yaw Anokwa wrote:
Mike,
On Wed, Mar 26, 2014 at 12:02 PM, Michael Stevens <michael.stevens.miis@gmail.com <javascript:;>> wrote:
51.0
at
Mike
Post: opendatakit@googlegroups.com <javascript:;>
Unsubscribe: opendatakit+unsubscribe@googlegroups.com <javascript:;>
email to opendatakit+unsubscribe@googlegroups.com <javascript:;>.
