Hi all,
I'm trying to setup my Eclipse environment to work with Aggregate 1.4.8.
First I would suggest to change the line of the CONFIGURE.txt file from:
(1) Finally, start Eclipse (Mars) and select this ODK Aggregate
workspace.
to:
(1) Finally, start Eclipse (Mars) and select the clone source code
directory/folder as workspace.
(I think it's more or less the same line than in previous versions of the
file.)
Well, I got it to compile but when I tried to deploy on the server I got
next error:
INFORMACIÓN: Loading properties file from class path resource
[logging.properties]
abr 19, 2016 11:22:15 AM
org.springframework.web.context.support.XmlWebApplicationContext refresh
ADVERTENCIA: Exception encountered during context initialization -
cancelling refresh attempt:
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'datastore' defined in class path resource
[odk-settings.xml]: Instantiation of bean failed; nested exception is
java.lang.NoClassDefFoundError:
com/google/appengine/api/datastore/EntityNotFoundException
abr 19, 2016 11:22:15 AM org.springframework.web.context.ContextLoader
initWebApplicationContext
GRAVE: Context initialization failed
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:1105)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1050)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:510)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
Does anyone suffer it before? Do you know the solution?
My working environment is Windows 7 64b, Java 1.7_0_79 and the rest as
suggested by the CONFIGURE.txt file
Thanks in advance and best regards.
A.S.: I would published on the ODK Developers group but I'm not allowed.
