I am having issues with my code once I deploy it to Google App
Engine. Here is a brief summary of what I have done. I'm developing
in Eclipse 3.7 – Indigo Service Release 1:
I modified the addNodeToHeader function in GenerateHeaderInfo.java
(I took out the "SiteLocation" prefix in the headers so that it will
work better with ESRI products).
Once the application is running on my Google App Engine Site, I am no
longer able to successfully add an ODK user under Site Admin. When I
try to change the password for a new user I get the following error:
“JSON change-password request to http://opendataholly.appspot.com.8888/ssl/user-manage-passwords
failed.”
I’m also unable to export a CSV. I get the following error:
“Oops! Google Chrome could not connect to opendataholly.appspot.com:
8888”
Thanks for your help,
Holly Orr
GIS Application Developer / Specialist
NYU - Global Technology Services
holly.orr@nyu.edu
Note that you should also probably have a realmString different from the
default for your deployment.
And you should probably change the siteKey and userServiceKey to some other
UUID value.
Once you make the changes, you need to run the Ant Build script in
odk-gae-settings, then refresh (F5) the eclipse-gae project, then deploy to
AppSpot. When you go back to local testing, you need to undo the 5 changes
I called out. You'll note that there are commented-out versions of those
lines in the file which makes that easy to do.
What is happening is that you didn't change the port values, and so the
requests are going to port 8888 rather than 80, and the site is not running
under https, but http, which means your password changes (though sent as
hashes) are visible to eavesdroppers.
On Fri, Jan 27, 2012 at 6:56 AM, Holly Orr wrote:
Hi -
I carefully followed all the directions under the "Minimal Eclipse
Setup" heading in the document
failed.”
8888”
Holly Orr
holly.orr@nyu.edu
