Dear all
I have a problem with my odk collect form. The form has been successfully
converted with the relevant bindings working; however, when using odk
briefcase to pull and export the data, responses are being seen as being
misplaced. This happens especially to the last variables and where
particular questions had been correctly skipped. For example, the response
to the automatically generated KEY variable could be shifted to another
variable inside. The instances/submissions forms however have the data in
correct order. I am using version 1.1.7 of odk collect.
Humphreys
My wild guess is that ODK Briefcase has an older version of the form,
so it's definition of how to treat the data is wrong.
Please file a issue with the Form attached and submission instances
that demonstrate it is not being parsed correctly. By providing the
form and the submission instances that don't parse we will be able to
debug and fix the problem.
To file an issue please go to the following url and click on "New Issue".
http://code.google.com/p/opendatakit/issues/list
You can attach files to the issue description. Please attach the form
and example problem submission instances to the issue so we can
re-create the issue.
Cheers,
Waylon
On Mon, Jun 4, 2012 at 6:18 PM, Humphreys Kabota wrote: > Dear all > I have a problem with my odk collect form. The form has been successfully > converted with the relevant bindings working; however, when using odk > briefcase to pull and export the data, responses are being seen as being > misplaced. This happens especially to the last variables and where > particular questions had been correctly skipped. For example, the response > to the automatically generated KEY variable could be shifted to another > variable inside. The instances/submissions forms however have the data in > correct order. I am using version 1.1.7 of odk collect. > Thanks, > Humphreys > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=enThanks Waylon for the quick response.
I have filed the issue and attached the necessary files as well.
Please let me know if I have done it right.
Regards,
Humphreys
On Jun 4, 6:44 pm, "W. Brunette" wrote: > My wild guess is that ODK Briefcase has an older version of the form, > so it's definition of how to treat the data is wrong. > > Please file a issue with the Form attached and submission instances > that demonstrate it is not being parsed correctly. By providing the > form and the submission instances that don't parse we will be able to > debug and fix the problem. > > To file an issue please go to the following url and click on "New Issue".http://code.google.com/p/opendatakit/issues/list > You can attach files to the issue description. Please attach the form > and example problem submission instances to the issue so we can > re-create the issue. > > Cheers, > Waylon > > On Mon, Jun 4, 2012 at 6:18 PM, Humphreys Kabota wrote: > > Dear all > > I have a problem with my odk collect form. The form has been successfully > > converted with the relevant bindings working; however, when using odk > > briefcase to pull and export the data, responses are being seen as being > > misplaced. This happens especially to the last variables and where > > particular questions had been correctly skipped. For example, the response > > to the automatically generated KEY variable could be shifted to another > > variable inside. The instances/submissions forms however have the data in > > correct order. I am using version 1.1.7 of odk collect. > > Thanks, > > Humphreys > > > -- > > Post: opendatakit@googlegroups.com > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > > Options:http://groups.google.com/group/opendatakit?hl=enCan you verify that the ODK Briefcase app is the latest ( 1.0.2.1)?
Thanks.
On Tue, Jun 5, 2012 at 12:08 AM, Humphreys Kabota < humphreys.kabota@investinknowledge.org> wrote:Thanks Waylon for the quick response.
Please let me know if I have done it right.Regards,
so it's definition of how to treat the data is wrong.Please file a issue with the Form attached and submission instances
debug and fix the problem.To file an issue please go to the following url and click on "New Issue".
re-create the issue.Cheers,
WaylonOn Mon, Jun 4, 2012 at 6:18 PM, Humphreys Kabota humphreys.kab...@investinknowledge.org wrote:
Dear all
successfullyconverted with the relevant bindings working; however, when using odk
beingmisplaced. This happens especially to the last variables and where
responseto the automatically generated KEY variable could be shifted to another
incorrect order. I am using version 1.1.7 of odk collect.
Humphreys--
Options:http://groups.google.com/group/opendatakit?hl=en--
