Hi ODK team,
I'm really enjoying using ODK -- super useful set of tools. Thank you. I am fairly new to the world of ODK (and programming in R and doing anything via CLI) but I am learning a lot.
Hopefully this explains my problem, but if something isn't clear I can try to give you more information.
I am trying to export forms using CLI (actually in R) and I keep getting an error. FWIW, I don't actually need the csv, but I think getting the csv first is probably the easiest way to create a data frame in R from my data?
Firstly I pull the forms using;
system("java -jar odkBriefcase_latest.jar -plla -U {URL here} -u {XXXX} -p {XXX} -sd THIS -id test_drink")
This runs for a while and - admittedly - ends in an error BUT the storage directory is created abd as far as I can work out all the submissions are actually pulled and are now on my computer in .xml . So I don't THINK this error matters?
The error is;
Error pulling a form: java.nio.file.NoSuchFileException: THIS/ODK Briefcase Storage/THIS/ODK Briefcase Storage/forms/test_drink/metadata.json (see the logs for more info)
Then I try to export the submissions using the following;
system("java -jar odkBriefcase_latest.jar -e -id test_drink -sd THIS -ed THAT -ef test_drink.csv")
But this comes straight back with an error( and the THAT export directory isn't created);
Unexpected error in Briefcase. Please review briefcase.log for more information. For help, post to https://forum.getodk.org/c/support
When I look at the logs the output is very long but I think the salient bit where it goes wrong is this bit;
2019-10-16 20:36:34,706 [main] ERROR org.opendatakit.briefcase.Launcher - Error
java.io.UncheckedIOException: java.nio.file.NoSuchFileException: THIS/ODK Briefcase Storage/THIS/ODK Briefcase Storage/forms/test_drink/metadata.json
It looks to me (although I don't really know) that it's looking for a storage directory called ~THIS/ODK Briefcase Storage/THIS/ODK Briefcase Storage ..... and presumably the storage directory is just ~THIS/ODK Briefcase Storage (without the second bit).
ODK aggregate server
Briefcase 1.17.0
Java Runtime Environment 1.8.221.11
Mac OS Mojave 10.14.6
RStudio 1.2.1335
I don't really have any ideas! I've updated to the latest versions of everything.
I've read through the documentation at https://docs.opendatakit.org/briefcase-using/
I think it's a problem with the export rather than the pull -- although given that the pull also returns an error (although seems to also work fine) I'm not sure.
Whilst this is all test data, I don't think I can give the server username and password because there's some other people's stuff on there (I'm using a server we use at LSHTM for training).
Screenshots are attached
46|689x465
