I am using the pulldata function on multiple questions, including one of type "date". When I fill out the form in an ODK Collect based app, there seems to be no problems: all pulldata questions get pre-populated well and I can proceed through the form, answer remaining questions and finalise it.
However, when I go to "Edit Saved Form" or send the finalised form to the server and look at the submission data, all questions after the "date" one are empty as if they have not been filled out.
The questions after the date question depend on the date and are as follows:
I have also attached a dummy csv file.
csv_prepop.csv (4.0 KB)
ODK Aggregate
Custom app based on ODK Collect 1.22.3
Android 9
I removed the pulldata function from the date question and everything works well (no data loss).
I have not yet found a solution that does not involve having to remove the pulldata function.
If it helps to share the entire form, I can send it to individuals but unfortunately cannot share it publicly.
The calculations used:
- pulldata('csv_prepop','child_dob','parent_study_id_key',${CS08})
- Get age in days: ${CS01}-${CS16}+1
- Get age in months: int(${calc-age-days}div30.44)
Note: CS01 is the date filling the form and defaults to today()
