I'm trying to extract a string of 5 characters into a calculate field using if and regex, however the result of the if statement is always 0.
The string of 5 characters is captured from a barcode and always in the format "AB1245" and includes the double speech marks. The if statement with regex to select the 5 characters between the two double speech marks in a calculate field pid2 is as follows:
(if(${pid}!=null,regex(${pid},'[A-Z]{2}\d\d\d\d\d'),''))
In the online regex tool https://regex101.com, the regex expression appears to work. But for some reason it fails in ODK. Any thoughts on where this might not be working?
OSX
ODK Collect v1.12.2
Searched online, https://regex101.com
