Dear all,
Am setting up an Aggregate Server in a new office environment. I
install Tomcat and I see it running (the Tomcat welcome page comes
up). I open the firewall "netsh firewall add portopening TCP 80 "ODK
Aggregate" ", then I move to another computer on the same network and
I try going to the IP address of the computer I have installed Tomcat
on from a browser. I get NO Tomcat Welcome page. I try installing on a
second and third machine just to eliminate the off chance that there
is a machine specific setting that is preventing my Tomcat Server
being accessed from a different machine. All three machines Tomcat
servers are inaccessible. Pinging them is not a problem, I get
replies. Am not sure what could be causing such behavious, it would be
useful if I could get some pointers so I know what to ask of the
network administrator (in case it is an issue of the network).
Any help greatly appreciated as always,
Tumaini
Pretty sure Tomcat runs HTTP on 8080 not 80. If you have HTTPS, it runs on 8443.
On Thu, May 24, 2012 at 8:14 AM, Tumaini Kilimba wrote:
> Dear all,
> Tumaini
First, confirm that you can open a browser on the local machine and see
Tomcat (e.g., http://localhost/).
It might very well be that you did not change the port to be port 80, but
are running with the default port 8080 (as Yaw notes); if that is the case,
you would need to specify http://localhost:8080/ to see Tomcat.
Then, confirm that the IP address you were using, and whatever port you
determined you needed (e.g., the :8080 or whatever) will get you to that
page, still from a browser on the machine running Tomcat. e.g.,
http://192.168.0.102/
Finally, move to another machine and see if that same URL works there. If
not, you need to look at your network, and involve your network admin.
Pinging is handled at a much lower layer and does not have anything to do
with Tomcat.
8443.
On Thu, May 24, 2012 at 8:14 AM, Tumaini Kilimba tkilimba@ihi.or.tz wrote:
Dear all,
Tumaini
Thanks guys. However, I had done all that before opening this ticket. I had
installed tomcat to run on port 80, and http://localhost/ works fine, I
see the welcome screen for Tomcat. I also *did *try using my IP
http://192.168.1.35/ and that too gives me the Tomcat welcome screen. The
issue is when I try and browse to http://192.168.1.35/ from a different
machine, I get NO welcome screen, I get an error:
The server at http can't be found, because the DNS lookup failed. DNS is
the web service that translates a website's name to its Internet address.
This error is most often caused by having no connection to the Internet or
a misconfigured network. It can also be caused by an unresponsive DNS
server or a firewall preventing Google Chrome from accessing the network.
Here are some suggestions:
- Reload http://http//192.168.2.65 this web page later.
- Check your Internet connection. Reboot any routers, modems, or other
network devices you may be using.
- Check your DNS settings. Contact your network administrator if you're
not sure what this means.
- Try disabling network prediction by following these steps: Go to *Wrench
menu > Options > Under the Hood *and deselect "Predict network actions
to improve page load performance." If this does not resolve the issue,
we recommend selecting this option again for improved performance.
- Try adding Google Chrome as a permitted program in your firewall or
antivirus software's settings. If it is already a permitted program, try
deleting it from the list of permitted programs and adding it again.
- If you use a proxy server, check your proxy settings or check with
your network administrator to make sure the proxy server is working.
- If you don't believe you should be using a proxy server, try the
following steps: Go to *Wrench menu > Options > Under the Hood > Change
proxy settings > LAN Settings *and deselect "Use a proxy server for your
LAN."
Error 105 (net::ERR_NAME_NOT_RESOLVED): Unable to resolve the server's DNS
address.
What sort of network issues could be causing this, as am quite confident
Tomcat is running on port 80 on my machine, and am trying to access my
machine from another machine within the same domain. I need to be able to
articulate to the network administrators what needs to be done to
facilitate tomcat serving up pages to other machines, so any pointers on
what I could ask them to check for would be great.
Any help appreciated,
Tumaini
with Tomcat.
on 8443.
Dear all,
Tumaini
PS - I also tried disabling my antivirus just in case that was the
cause.... no joy.
> had installed tomcat to run on port 80, and http://localhost/ works
> fine, I see the welcome screen for Tomcat. I also *did *try using my IP
> The server at *http* can't be found, because the DNS lookup failed. DNS
> is the web service that translates a website's name to its Internet
> address. This error is most often caused by having no connection to the
> Internet or a misconfigured network. It can also be caused by an
> unresponsive DNS server or a firewall preventing Google Chrome from
> - Reload this web page later.
> you're not sure what this means.
> Change proxy settings > LAN Settings *and deselect "Use a proxy server
> for your LAN."
> address.
> Tumaini
>> If not, you need to look at your network, and involve your network admin.
>> with Tomcat.
>> Mitch
>>> on 8443.
>>> > Dear all,
>>> > Tumaini
>> Mitch Sundt
>> Software Engineer
The error message seems to indicate that it is trying to find the hostname
"http", and is not looking for 192.168.1.35.
You might check that you are browsing to the url http://192.168.1.35/ and
not http://http://192.168.1.35/
cause.... no joy.
screen. The issue is when I try and browse to http://192.168.1.35/ from
a different machine, I get NO welcome screen, I get an error:
other network devices you may be using.
actions to improve page load performance." If this does not resolve
the issue, we recommend selecting this option again for improved
performance.
server for your LAN."
DNS address.
Tumaini
but are running with the default port 8080 (as Yaw notes); if that is the
case, you would need to specify http://localhost:8080/ to see Tomcat.
do with Tomcat.
on 8443.
Dear all,
Tumaini
Unsubscribe: opendatakit+unsubscribe@**googlegroups.comopendatakit%2Bunsubscribe@googlegroups.com
