Hi everyone,
I'm the one on whose phone these errors happen. A few clarifications:
- I've tried it on several Galaxy Minis SG-5570 3. Model Number:
GT-S5570. The problem is consistent: when a full survey is entered
(meaning that no large skips are made), it times out when saving.
- Interestingly, when I keep touching the screen as it's saving, not
letting it go to sleep, it ends up saving.
- The second log attached (alogcat.2012-02-13-15-27-38+0100.txt) is
about the same crash described in the Stack Trace info.
- It's not possible to save the form at any point mid-way. If I try to
do that it says "Response required". 99% of the questions are required.
Any ideas of what could be causing this instability?
Laura
On Mon, Feb 13, 2012 at 3:58 PM, Evelyn Castle <evelyn@ehealthnigeria.org wrote:
Hi Yaw and Gaetano,
Unfortunately, the only Galaxy Mini that I was able to test it on had the
upgraded Android version (Gingerbread). The phones that are not working are
still running 2.2.1. When I tried the form with the upgraded version of
Android, I was able to save the form fine and was not able to recreate
their error. However, on the Galaxy Mini, it took over a minute for the
form to load.
The error is only occurring when the survey is filled out with a lot of
information. So if they fill out only a few questions and then save the
form, it will save and can be uploaded. However, if they fill out the form
completely (say with 10 children's information, aka. a ton of data), then
when they try to save the form, one of 2 things happen.
- the form says it is saving and then goes back to the home screen but
the form is not in the "send finalized forms" section or "edit saved
forms" section
- The application force closes
Here is the stack trace from one of the times the application force
closed:
java.lang.RuntimeException: Unable to pause activity
{org.odk.collect.android/org.odk.collect.android.
activities.FormEntryActicity}:
java.lang.ClassCaseException: android.view.View
at android.app.ActivityThread.performPauseActivity(
ActivityThread.java:3354)
ActivityThread.java:3311)
at android.app.ActivityThread.handlePauseActivity(
ActivityThread.java:3294)
at android.app.ActivityThread.access$2500(ActivityThread.java:126)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2049)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loop(Looper.java:123)
at android.app.ActivityThread.main(ActivityThread.java:4633)
at java.lang.reflext.Method.invokeNative(Native Method)
at java.lang.reflect.Medhod.invoke(Method.java:521)
at com.android.internal.os.ZygoteInit(MethodAndArgsCaller.run(
ZygoteInit.java:858)
Also attached to this email (also made an issue herehttp://code.google.com/p/opendatakit/issues/detail?id=515&thanks=515&ts=1329145069)
are the logs from when the survey just returned to the home screen.
Evelyn
On Sat, Feb 11, 2012 at 4:25 PM, Yaw Anokwa yanokwa@gmail.com wrote:
Evelyn,
Agreed with Gaetano. This could be a device issue. Generally, you see
power and memory issues when the form is loading the first time, but
not on save.
Does the problem happen when they save using the menu on say the first
prompt? Or the last prompt? What happens if you reboot the phone and
try the last screen. Does it crash then?
The lack of a Report button has to do with the build of Android on
that phone. Some phones have it, others don't. In
http://opendatakit.org/help/faq/ under "How do I get a stack trace or
log after an Android "Force Close"" we have instructions on how to get
a log of exactly where the phone crashed. Follow those steps and post
the trace and a description of how it was caused on the Galaxy Mini at
http://code.google.com/p/opendatakit/issues/list. Please describe the
version of Android on the phone, the version of collect and attach the
form there. We'll try to reproduce it on our least powerful device.
On Fri, Feb 10, 2012 at 11:52, Gaetano Borriello
