I much appreciate your comments, Chris.
I agree with the laboriousness for per-question comments. The idea is
that this is only really workable for form-builders where you would just
tick a box and that would generate the XLSForm or XForm output
automatically.
Okay, thanks! That helps.
It's still a bit unclear to me whether appearance+for is ideal vs.
some other way of specifying both the functionality desired and the
link(s). For example, if you wanted a comment on a set of questions rather
than just one, how would that happen? Using "for", you might get locked
into a 1-to-1 design that turns out to be less than ideal for comment
facilities.
As a point of reference (and, I realize, general irritation), we added
comment capability into SurveyCTO some years back. And we did it by adding
a new field type that would accept comments form-wide. So, essentially, if
you added a "comments" field to your form, then a context-menu option to
add a comment would be available survey-wide, and the comments field would
end up holding a .csv file with comments linked to the fields with which
they were associated. So, you might get no .csv file, a .csv file with a
single comment for a single field, or a .csv file with potentially lots of
comments. These comments were held separately from the core form data, in
separate (but attached) .csv files so that you could import and manage them
separately from your core analysis. It was ad-hoc and designed to meet some
users' needs, though certainly imperfectly. Client UI's could differ in how
they allowed addition of comments, but we used the same basic approach in
both our Android and web UI's (a context menu).
In my view, most users who want to accept comments likely want to
accept them either everywhere or at least in most places -- so having to
code comment fields separately, field-by-field, would be tremendously
laborious to the point of not being useful. That's just my opinion, though,
and obviously you have at least one client willing to pay for the
field-by-field option.
It also seems quite dangerous to allow any kind of blanket bypassing
of validation, so your approach to that (allowing them to code this into
the validation itself) seems like a really smart one. In a great many
cases, forms are designed such that people reasonably expect -- perhaps
within the logic and UI of the form itself, but certainly in the back-end
processing and analysis -- that required fields will be required and that
constraints will be enforced. Once you start allowing people to escape
validation, the design, testing, and analysis tasks become just so much
more complex. While we do have users who occasionally ask for
blanket-validation-escape options, we generally talk them out of it. And we
haven't been willing to build such things into SurveyCTO, believing that
even those who request it would be poorly served by the consequences.
Chris
On Fri, Jun 24, 2016 at 11:36 AM Martijn van de Rijdt < mar...@enketo.org> wrote:
Thanks Chris,
The use case that prompted this change was the desire to comment on
questions (similar to what SMAP server is doing on their ODK Collect fork -
but without the limitation it has beyond their use case) and enter those
comments by clicking a button next to the question that would reveal some
kind of modal. In addition, the presence or value of a comment would have
to allow bypassing validation. E.g. question A is required, unless there is
a comment on that question. So eventually after going through many complex
options, we can back to the idea that those comment questions should be
coded into the XForm like any other question. Any validation logic can thus
be coded normally with XPath. The additional benefit is that labels,
translations, hints, etc. are also completely flexible and don't have to be
hardcoded. I should also note that the client that has paid for this, will
have different types of 'comment' questions and one question could even
have multiple comment types. This is far beyond the scope of this proposal,
but it played a role in coming up with this implementation.
So to do this, we could use the "for" attribute to visually link
from the comment question to the question it links with. Any logic
(relevant, constraint) links are separate from that.
A client, such as Enketo or ODK Collect, would require only one more
XForm addition to respond to the use case described above, which is a new
appearance. The one I wanted to propose, if we make the "for" attribute an
official OpenRosa feature, is to use appearance="comment".
A second (optional) additional proposal would be to link the question
node in the model with the comment node(s) (note the link goes in a
different direction here). The objective would be to facilitate the
presentation of submitted data on the OpenRosa server for easy analysis
without having to evaluate the XPath expressions in "for" attributes in the
XForm binds. That addition would not be required or used by Enketo or ODK
Collect. It's purely for the server. Let me know if you want me to
elaborate further on this already.
Cheers,
Martijn
On Thursday, June 23, 2016 at 11:12:51 AM UTC-6, Christopher Robert wrote:
Hi Martijn,
Sounds interesting. Can you say any more about the likely use cases
and the additional specification extensions those might require?
I ask only because it seems a bit difficult to think about this
"linking of questions" issue separated from the nature of the links
themselves -- and what other properties or parameters would be required to
support those types of links. For example, you might say that when field q3
has a relevance expression like "q1+q2 < 100", then q3 is linked in a way
with q1 and q2: its visibility depends on q1 and q2. Likewise, constraints
can include links, labels can include links, and so we have varied ways in
which fields are already related to one another. And in a sense you can say
that all of the fields within a group (with the field-list appearance or
otherwise) are related.
In none of those cases is a separate "for" construct necessary, and
so it gets me thinking about what other kinds of links might or might not
require (or benefit from) a "for" linkage. That's why I thought more use
cases might be useful, to determine whether they share the need for a new
"for"-type linkage, or if, like the existing linkages, they might be
somehow implicit or arranged in some other way. For example, if another
extension might be necessary to support modal pop-ups, then might that
extension itself not have its own way of specifying the linkages?
Chris
On Thu, Jun 23, 2016 at 12:57 PM Martijn van de Rijdt < mar...@enketo.org> wrote:
Hi ODK Devs,
We added some functionality to Enketo and wanted to propose a
related addition to the OpenRosa/ODK XForm specification.
If you agree with this addition to the XForms spec (or an
alternative), I'll add it to the documentation and use the OpenRosa
namespace. If, not we'll just consider it an Enketo-specific extension and
use an Enketo namespace. In either case the XForms are functional in ODK
Collect, because the addition is just ignored.
Requirement:
Visually link two questions together. Can be used for various
features, e.g. one question could be a comment on another question.
Proposal:
Add a namespaced `for"bind attribute, like this:
The for attribute contains a relative or absolute path to the
question it links with. So in combination with an appearance you could now
visually link these questions together in creative ways that regular XForm
groups do not allow. E.g. add a button to the linked question that when
clicked shows a modal containing the other question. There are no
restrictions, special assumptions or magic. A question could have multiple
questions linked to it for example.
If there is some enthusiasm for this I'll follow up with another
more specific proposal to build upon this XForm addition to create a very
flexible comment feature.
Cheers,
Martijn
Revolutionizing data collection since 2012.
Enketo https://enketo.org/ | LinkedIn
http://www.linkedin.com/company/enketo-llc | GitHub
https://github.com/enketo | Twitter
https://twitter.com/enketo | Blog http://blog.enketo.org/
send an email to
opendatakit-developers+unsubscribe@googlegroups.com.
send an email to opendatakit-developers+unsubscribe@googlegroups.com.
https://groups.google.com/d/topic/opendatakit-developers/SaNMPr9eSyQ/unsubscribe
