Is it possible to limit the set of data a user can pull from aggregate
using briefcase. For instance, a specific user can only pull data where a
field name is equal to a certain value. For example, an area supervisor can
only pull the set of data/records pertaining to his area assignment (where
fieldname 'town' is equal to the area he is assigned to).
Currently no. My guess is that this is a non-trivial feature to add
directly to Aggregate. Might be easier to send the data to Fusion
Tables and see if you can filter from there...
Is it possible to limit the set of data a user can pull from aggregate using
briefcase. For instance, a specific user can only pull data where a field
name is equal to a certain value. For example, an area supervisor can only
On Wed, May 29, 2013 at 1:11 PM, Yaw Anokwa wrote:
Vinia,
using
only
I know this is an old thread, but am interested to know if you were able to
achieve a filtered pull (e.g. by username)?
Andrew
On Wednesday, 29 May 2013 07:20:45 UTC+2, vinia wrote:
> Thanks, Yaw. Sent you an email.
> On Wed, May 29, 2013 at 1:11 PM, Yaw Anokwa <yan...@nafundi.com > wrote:
>> Vinia,
>> Yaw
>> On Tue, May 28, 2013 at 7:36 AM, vinia <viniam...@gmail.com > wrote:
>> > Hi.
>> using
>> field
>> only
>> > Thanks,
>> > Vinia
>> > Post: opend...@googlegroups.com
>> > Unsubscribe: opendatakit...@googlegroups.com
>> > Options: http://groups.google.com/group/opendatakit?hl=en
>> > You received this message because you are subscribed to the Google
>> Groups
>> > "ODK Community" group.
>> > To unsubscribe from this group and stop receiving emails from it, send
>> an
>> > email to opendatakit...@googlegroups.com .
>> > For more options, visit https://groups.google.com/groups/opt_out.
using
field
only
On Wednesday, 25 May 2016 18:38:25 UTC+2, Mitch Sundt wrote:
> There is no functionality in ODK Aggregate that could be used to achieve
> this.
> On Wed, May 25, 2016 at 4:10 AM, Andrew <acawo...@gmail.com > wrote:
>> Hi Vinia,
>> to achieve a filtered pull (e.g. by username)?
>> Thanks,
>> Andrew
>>>> Vinia,
>>>> Yaw
>>>> On Tue, May 28, 2013 at 7:36 AM, vinia wrote:
>>>> > Hi.
>>>> aggregate using
>>>> field
>>>> only
>>>> > Thanks,
>>>> > Vinia
>>>> Groups
>>>> send an
>>>> > email to opendatakit...@googlegroups.com.
>>>> Groups "ODK Community" group.
>>>> an email to opendatakit...@googlegroups.com.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
