Hi All,
I have a list of two columns saved into CSV format file, I followed the
instructions to make it pull from CSV, but it doesn't read anything from
there.
I put the CSV file in ODK/forms with the form xml file, and this is how I
do it:
begin group barcode barcode box_id Scan the barcode of the box now yes end
group calculate items The items inside
the box are: pulldata('barcode_items', 'eitems', 'barcode', ${box_id})
begin group note note contents.note The
contents of this ${box_id} box are: ${items} end group
Hanan,
Assuming your form is /sdcard/odk/forms/myform.xml, the CSV needs to
be in /sdcard/odk/forms/myform-media/whatever.csv.
On Mon, Aug 31, 2015 at 8:07 AM, Hanan Aqilan hjameelq@gmail.com wrote:
Hi All,
I have a list of two columns saved into CSV format file, I followed the instructions to make it pull from CSV, but it doesn't read anything from there.
I put the CSV file in ODK/forms with the form xml file, and this is how I do it:
begin group barcode
end group
calculate items The items inside the box are: pulldata('barcode_items', 'eitems', 'barcode', ${box_id})
begin group note
note contents.note The contents of this ${box_id} box are: ${items}
end group
