I am having an issue using the pulldata function with a larger csv files. Basically if the csv file is composed out of few rows, it works as expected but it fails with larger files. By failure I mean, no data is pulled from the csv in my form's calculated fields. I'll need to make something like this work with close to 20k rows in 5-10 columns. Is there a better way to achive such functionality, other than external csv file?
I could reproduce this with ODK 1.30 and 1.29.5 on Android 11 running on OnePlus 8
I have reduced the number of lines in the csv file and the form worked as expected.
My XML form and a csv file with fake data is in the attached archive. Open the form with the file as is, enter 1234567 and the other fields in beneficiary group won't be populated. Reduce the rows in the csv file to 20, load the form again, type 1234567 in the Search by ID field and the beneficiary group should be correctly populated.
sites.zip (37.3 KB)
