Below is the error;
Preparing for upload of form definition with 0 media attachments
Uploading form definition with no media attachments
UPLOAD FAILED: Form definition upload failed. Detailed error: Unexpected exception: java.net.SocketException: Software caused connection abort: socket write error
unable to open form database: Database lock acquisition failure: lockFile: org.hsqldb.persist.LockFile@da773d75[file =C:\ODKaPS\Storage\ODK Briefcase Storage\forms\XXXXXXXXXXXXXX\info.hsqldb\info.lck, exists=true, locked=false, valid=false, ] method: checkHeartbeat read: 2018-08-31 09:42:55 heartbeat - read: -7643 ms.
Partially successful upload...
ODK Briefacse 1.9, running on Windows 10
None that I could describe
Seeking ideas
The are forms that could not upload from the Android devices and we copied the ODK to a Laptop
