Hi fellow Odkers,
Has anyone figured out how to go about this problem?
i would like to pull a label from a single select question and use it in a subsequent question however, each time I use ${field_name} to extract it, I get the internal value associated with the label and not the label itself. See attachment.
I would like the subsequent question to read like Which year did you sit for your KCPE exams in ${school_X} school?
It would be great if you give solution for both single and multi select scenarios.
biz.xlsx (12.2 KB)
