QR Code generation on screen (and not print)
I'm wondering if ODK could generate a QR code (or bar code) image as a final note of the form. (a summary of the most important question)
I need such a thing so that an other interviewer could flash this code to run an other part of the interview by reusing the QR Content.
I thing the QR reader but not the QR generator (except for the ODK parameters' sharing)
ODK 1.20
I wanted to use the external app launch with the intent provide by QR Droid Services but I did'nt really have any success with intent (this app is not the only one I have problem with)
The QR Droid app is there : http://qrdroid.com/get/
If someone else as the same issue, here is my conclusion after some test
  • Install QR Droid
  • use calculate to construct your message with all the answer you need in QR Code
  • use calculate to put " and " at the beginning and at the end of the message.
    I use concat('"',${my_message},'"')
    In the xls form add the intent like that :
type | name_________ | label _____| apparence
text | QR_generation | QR message | ex:la.droid.qr.encode(la.droid.qr.image=true,la.droid.qr.code=${msg_OK})
When you press the button Start the QR code is generated by QR droid and is in the historic
My issue : I couldn't succeed in having the st image save somewhere to get it back on ODK
I read : http://qrdroid.com/android-developers/
The result should be in this la.droid.qr.result
but I can't figure how to get this using ODK.
I'm not fare away... but still not perfect
