When trying to use the barcode scanning function of an ODK form, there is
an error which say no barcode scanner found. Is it referring to a third
party android barcode scanner? If it is, i don't have any and can anyone
probably recommend a good andoird barcode scanning app which is compatible
with ODK? Thank you!
On Fri, Nov 25, 2011 at 21:16, Alison Perez wrote:
> Good day!
> When trying to use the barcode scanning function of an ODK form, there is an
> error which say no barcode scanner found. Is it referring to a third party
> android barcode scanner? If it is, i don't have any and can anyone probably
> recommend a good andoird barcode scanning app which is compatible with ODK?
> Thank you!
