In the XLSForm help, a usage is shown like this: *select_one yesno or_other
but it also says:
*A second column will have the answer for the questions which the user
selected ‘other.’ This makes doing data analysis more cumbersome, so we
don’t recommend the or_other construct for large-scale data collection
efforts. The option is perfectly appropriate for pilots, however.*
What is the "proper" way to make a yes, no, other question? Is it possible
to have one column in the final csv that shows values of yes, no, and all
the things the people have typed into the other box?
Hi Curtis,
There isn't really a proper way to implement yes/no/other questions, it's
more of a trade-off. The or_other flag is a convenient shortcut, but you
give up control over your other option's label and the specify other
question.
If you want to make everything show up in a single column you could make
calculate question with this formula:
if(selected(${select_one_question}, 'other'), ${specify_other_question},
${select_one_question})
Since you need the name of the specify_other question, I would suggest
creating one yourself rather than using the or_other flag. (You might be
able to use the generated name which I believe is the select question's
name with "_other" appended to it, but I haven't tested this.)
Regards,
-Nathan
> or_other*
> but it also says:
> Curtis Broderick
> EpiConcept
> France
Hi Curtis,
question.
Regards,
-Nathan
