Quick ODK Build Q
I just created a form with build and tried adding it to aggregate.
It failed citing that the form is missing a "form id". I can figure out how
to add that manually easy enough. Is there a way to do this via ODK Build
though?
Matt
Curious. ODK Build should be doing this automatically for you; I'll check up on it to see why it's not doing so.
—Clint
It failed citing that the form is missing a "form id". I can figure out how to add that manually easy enough. Is there a way to do this via ODK Build though?
Matt
Hi Matt,
I pushed a patch just now that should clear things up. See if that helps when you get a chance.
—Clint
—Clint
Matt
Thanks! Will try it out in a bit and let you know.
··· On Mon, Nov 22, 2010 at 1:55 AM, Clint Tseng wrote:
Hi Matt,
—Clint
—Clint
though?
Matt
Unsubscribe: opendatakit+unsubscribe@googlegroups.comopendatakit%2Bunsubscribe@googlegroups.com
ICT Director
Millennium Villages Project
Columbia University, NYC
M: +1.646.463.1273
Skype: mlberg
I have also had a problem with ODK build and the group/looping option.
I keep getting an error in Validate and Collect.
This is what the error states:
Checking XML...
Parsing form...
Title: "Test Group"
Warning: Control binding [/data/Test/Test/Test2] matches no nodes
Warning: Control binding [/data/Test/Test/Test3] matches no nodes
Form is valid. See above for warnings (if any).
Here is the code for this example: dpaste.com/278534
I gave up after a while and used the Household Survey sample code.
··· On Nov 22, 12:48 am, Matt Berg wrote: > Thanks! Will try it out in a bit and let you know. > > > > > > > > > > On Mon, Nov 22, 2010 at 1:55 AM, Clint Tseng wrote: > > Hi Matt, > > > I pushed a patch just now that should clear things up. See if that helps > > when you get a chance. > > > Thanks, > > —Clint > > > On Nov 20, 2010, at 8:22 PM, Clint Tseng wrote: > > > Curious. ODK Build should be doing this automatically for you; I'll check > > up on it to see why it's not doing so. > > > Thanks, > > —Clint > > > On Nov 20, 2010, at 5:38 PM, Matt Berg wrote: > > > I just created a form with build and tried adding it to aggregate. > > > It failed citing that the form is missing a "form id". I can figure out how > > to add that manually easy enough. Is there a way to do this via ODK Build > > though? > > > Thanks, > > > Matt > > > -- > > Post: opendatakit@googlegroups.com > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > > Options:http://groups.google.com/group/opendatakit?hl=en > > > -- > > Post: opendatakit@googlegroups.com > > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > > Options:http://groups.google.com/group/opendatakit?hl=en > > -- > ICT Director > Millennium Villages Project > Columbia University, NYC > M: +1.646.463.1273 > Skype: mlberg
this is a bug on our part. i've filed the issue at
http://code.google.com/p/opendatakit/issues/detail?id=151 and we'll
fix it asap.
··· On Mon, Nov 22, 2010 at 11:33, Ulli wrote: > I have also had a problem with ODK build and the group/looping option. > I keep getting an error in Validate and Collect. > > This is what the error states: > Checking XML... > Parsing form... > Title: "Test Group" > Warning: Control binding [/data/Test/Test/Test2] matches no nodes > Warning: Control binding [/data/Test/Test/Test3] matches no nodes > >>> Form is valid. See above for warnings (if any). > > Here is the code for this example: dpaste.com/278534 > > I gave up after a while and used the Household Survey sample code. > > > > On Nov 22, 12:48 am, Matt Berg wrote: >> Thanks! Will try it out in a bit and let you know. >> >> >> >> >> >> >> >> >> >> On Mon, Nov 22, 2010 at 1:55 AM, Clint Tseng wrote: >> > Hi Matt, >> >> > I pushed a patch just now that should clear things up. See if that helps >> > when you get a chance. >> >> > Thanks, >> > —Clint >> >> > On Nov 20, 2010, at 8:22 PM, Clint Tseng wrote: >> >> > Curious. ODK Build should be doing this automatically for you; I'll check >> > up on it to see why it's not doing so. >> >> > Thanks, >> > —Clint >> >> > On Nov 20, 2010, at 5:38 PM, Matt Berg wrote: >> >> > I just created a form with build and tried adding it to aggregate. >> >> > It failed citing that the form is missing a "form id". I can figure out how >> > to add that manually easy enough. Is there a way to do this via ODK Build >> > though? >> >> > Thanks, >> >> > Matt >> >> > -- >> > Post: opendatakit@googlegroups.com >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> > Options:http://groups.google.com/group/opendatakit?hl=en >> >> > -- >> > Post: opendatakit@googlegroups.com >> > Unsubscribe: opendatakit+unsubscribe@googlegroups.com >> > Options:http://groups.google.com/group/opendatakit?hl=en >> >> -- >> ICT Director >> Millennium Villages Project >> Columbia University, NYC >> M: +1.646.463.1273 >> Skype: mlberg > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >
